17445 Discussions
combing Intel database
hello
i am looking to clarify some understanding using the Intel classification schema of processors.
here: http://www.intel.com/support/processors/sb/cs-012822.htm http://www.intel.com/support/processors/sb/cs-012822.htm
we see in the title:
Optimizing the Linux* Kernel for the Intel(R) Pentium(R) 4 processor
I am researching the " Intel Pentium B960 ".
as far as the number 4 as shown in the title. would the number 4 designate a series. Or what is the number four for.
The bottom line here is to find a article similar to the one shown at http://www.intel.com/support/processors/sb/cs-012822.htm http://www.intel.com/support/processors/sb/cs-012822.htm, yet for the " Intel Pentium B960 ".
And similar articles for other Intel processors.
Is there a Directory, Database, tables with a word associated with it that would hold the information that is similar in nature to what is available at
I did do a search here at Intel and went, no where.
thank you
O, i did the online survey, but not to sure how far that would go, while limited to x number of chars.
"Intel(R) Pentium(R) 4 processors" is a processor family. Information on Intel(R) processors can be found here: http://ark.intel.com/ http://ark.intel.com/
I will proceed to do some research on your query and will get back to you as soon as possible.
Recent processors from Intel do not require any kind of optimization and if it's required, you should select that most updated processor option from the Kernel optimization utility that you are or will be using. Due to this, there is no similar document for the processor in question.
