告知
17261 ディスカッション
dh87rl BIOS update
TheBosnian
ビギナー
4,026件の閲覧回数
In one of these forums,I have found the latest update for dh87rl which was in 2018,the version is 0332.Mine version is 0320,I was wondering if it is safe to update from 0320 to 0332?
0 件の賞賛
2 返答(返信)
n_scott_pearson
スーパーユーザー
3,978件の閲覧回数
Provided you have a processor launched before April 2014 (i.e., you don't have a Haswell Refresh processor), you should be ok upgrading to BIOS 332. Because of security fixes in BIOS releases subsequent to BIOS 320, I recommend installing BIOS 332 using the jumper-based BIOS Recovery process. Here is my procedure for this process:
  1. NOTE: Read these instructions completely before starting. Follow all instructions EXACTLY.
  2. On some other Windows-based PC, download the .BIO file for the BIOS release you wish to install.
  3. Insert a 32GB or smaller (the smaller the better) USB 2.0 flash drive into the PC. Do not use USB 3.0 flash drives (most are not compatible). It is also better (though not required) to use a flash drive that has an access LED that you can watch.
  4. Format this USB flash drive using the Windows Format applet. Specify to install the FAT32 file system (Important: NOT vFAT, NOT exFAT; FAT32 only). You must also specify that the Quick Format option be Disabled (unchecked).
  5. NOTE: If FAT32 is not offered as a choice by the Format applet, your flash drive is too big; use another.
  6. Copy the .BIO file into the root folder of this USB flash drive. This should be the only .BIO file in the root folder of the USB flash drive.
  7. Properly eject the USB flash drive. Do not just yank it out. Do this from File Explorer or using the Safely Remove Hardware and Eject Media System Tray applet.
  8. Power off the Desktop Board system.
  9. Remove the yellow BIOS Configuration jumper from the board. It will be the only yellow jumper on the board; others will usually be black.
  10. Plug the USB flash drive into one of the black USB 2.0 ports on the back panel of the board. Avoid using blue USB 3.0 or Yellow USB 2.0/3.0 charging ports, and avoid using front panel USB ports.
  11. Power on the system.
  12. The BIOS Recovery process should start automatically. You should see a progress report on your main monitor.
  13. NOTE: If you do not see a progress report displayed on a monitor, do not power off the system for at least 15 minutes. While it is rare, it is possible for the process to proceed without an onscreen display; you must give it ample time to complete, just in case.
  14. When the BIOS Recovery process is complete, you will be asked to power off the system. Do so.
  15. Restore the yellow BIOS Configuration jumper to the pins it was on previously. This should be across pins 1 and 2 of this (three pin) header.
  16. Remove the USB flash drive from the back panel of the board.
  17. Power on the board.
  18. Immediately begin pressing the F2 key on your keyboard, over and over (approx. once per second) until you see a BIOS Setup (or Visual BIOS) screen displayed.
  19. Verify, using the BIOS version string, that the BIOS installed properly. Stop if it isn't.
  20. Press the F9 key (followed by the Y key) to reset the BIOS configuration.
  21. Press the F10 key (followed by the Y key) to save the modified BIOS Configuration and exit BIOS Setup.
  22. Once screen is cleared (goes black), begin pressing the F2 key, over and over, until you see the BIOS Setup/Visual BIOS screen displayed again.
  23. Make any changes to the BIOS configuration that you desire (for example, disabling NUMLOCK) or that you require (for example, setting Boot Order, enabling UEFI, etc.).
  24. Press the F10 key (followed by the Y key) to save the BIOS Configuration and exit BIOS Setup.
  25. Test.
Here are some additional thoughts:
  • If BIOS Recovery will not start, try using a different USB port. If you run out of black USB 2.0 ports, you can try using the blue USB 3.0 or yellow USB 2.0/3.0 charging ports on the back panel as well. You can also try using front panel USB ports.
  • If switching USB ports doesn't work, try using a different USB flash drive. Remember that all USB flash drives must be reformatted at least once using the process described in Step 4 above.
  • As always, it is helpful to use a USB flash drive that has an access LED so that you can visually see if it is being accessed.
  • If you are seeing the USB flash drive being accessed but BIOS Recovery does not start, a common cause is compatibility with the memory present. The BIOS Recovery engine, as it is with USB 3.0 flash drives, can be very picky with regards to memory compatibility. Try removing all but one DIMM/SODIMM.
  • For more information on the BIOS Recovery process, consult Intel Desktop Boards Recovery BIOS Update Instructions.
Hope this helps,
n_scott_pearson
スーパーユーザー
3,978件の閲覧回数
Here's the BIOS if you haven't downloaded it as yet. I also attached what documents I have for the RL board.
返信
