17041 Discussions
driver update reinstal issue
RBeel
Every few days i need to download and reinstall the same driver update for my intel cpu
this happens once every few days and is very annoying because it makes my cpu or memory usage go to 99% wich makes my pc very slow imidiatly and can be very stresful mid game session
my specs are
motherboard : Asrock fatal1ty b85 killer
memory : 2x crucial ballistix sport 8 gb
hardisk: WD green WD 20 ezrx
SSD:BX100 250 gb ssd
cpu :intel core i 7 4790 /3.6 Ghz
Gpu: Sapphire nitro r9 380 4g D5 (amd)
Hi Robbe_B,
Let's try testing your system with the Intel® Processor Diagnostic Tool, to verify the functionality of your system. The diagnostic checks for brand identification, verifies the processor operating frequency, tests specific processor features, and performs a stress test on the processor.
Please attach the results to your answer.
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Are you getting any error message? What is the driver version you are using?
Hellen.
RBeel
I can respond now but tomorrow i wil be on vacation for a few weeks so i cant respond during that time
--- IPDT64 - Revision: 3.0.0.25.W.MP
--- IPDT64 - Start Time: 7/16/2016 12:13:57 PM
Processor 1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Sat Jul 16 12:13:58 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Sat Jul 16 12:13:58 2016
Total Time: seconds: 0
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 40 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
CPU Frequency Test
Module Version: 1.0.14.64b.W
Start Time: Sat Jul 16 12:13:59 2016
Test Result - PASS
Processor Name: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
Expected CPU Frequency: 3.60
Detected CPU Frequency: 3.8526
Expected Base Clock: 100
Detected Base Clock: 101.384
Expected frequency - The highest frequency at which the tested processor was manufactured to operate
Detected frequency - The frequency at which the tested processor is currently operating
Power management modes can create marginally higher or lower detected frequency
than expected frequency. Small variations in clock frequencies are common.
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Sat Jul 16 12:14:00 2016
Total Time: seconds: 1
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Sat Jul 16 12:14:00 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 489.6
Error: 0
--- Floating Point Test Passed!!!---
End Time: Sat Jul 16 12:14:02 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Sat Jul 16 12:14:02 2016
Test Result - PASS
Operation Per Second: 4.65205e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Sat Jul 16 12:14:04 2016
Cache Test
Start Time: Sat Jul 16 12:14:04 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Start Time: Sat Jul 16 12:14:05 2016
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
End Time: Sat Jul 16 12:14:05 2016
IMC Test
Module Version: 1.0.7.64b.W
Start Time: Sat Jul 16 12:14:06 2016
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 16.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
End Time: Sat Jul 16 12:14:06 2016
PCH Test
Module Version: 1.0.9.64b.W
Test Result - PASS
Chipset : Intel(R) B85 Express Chipset
2 device connected to PCI Express Port 1
1 : AMD Radeon (TM) R9 380 Series
2 : High Definition Audio Bus
No d...
For sure Robee_B this case will be open till that; by the way, your processor seems to be fine, it passes all the tests. This is the max temperature allowed to your processor 72.72°C.
What is the driver you have to reinstall?
Hellen.
RBeel
intel chipset software (INF Update utility exe only)
RBeel
its version 10.0.10586.494
package version 10.1.1.14
Hi Robbe_B,
We recommend you work with your computer manufacturer before installing our driver so you don't lose features or customizations.
I suggest you to try ASRock latest driver version:
http://www.asrock.com/mb/Intel/Fatal1ty%20B85%20Killer/?cat=Download&os=Win1064 http://www.asrock.com/mb/Intel/Fatal1ty%20B85%20Killer/?cat=Download&os=Win1064
Unless you are installing an operating system, you do not need to install the Intel® Chipset Software Installation Utility.
Learn about Intel® Chipset Software Installation Utility:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005835.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000005835.html
Please let me know the outcome, hope this helps you.
Hellen.
RBeel
i updated asrock but i still had the same problem 4 times in about 2 weeks
Hi Robbe_B,
I'm sorry about this, from this point I recommend you to contact your motherboard manufacturer, and report to them this issue you are getting with the INF driver.
We sell our Intel chipsets and processors to third party manufacturers and they design their own computers with their own features, settings, and capabilities. For that reason they design their own drivers, to meet the exact specifications on their computers.
Contact Technical Support ASRock*
http://www.asrock.com/support/index.asp http://www.asrock.com/support/index.asp
Hellen.
RBeel
thanks for all the help i will look what they can do
Hi Robbe_B,
If there is anything else you need, do not hesitate to contact us back.
Hellen.
