help please
North America Customer Support CenterNorth America
Mailing Address:
North America Service Center Intel Customer Support AG4-425 5200 NE Elam Young Parkway Hillsboro, OR 97124-6497 USAProduct CategoryPhone or contact information and Available SupportBusiness hours for phone supportPresales Inquiries1-800-538-3373
http://www.intel.com/feedback.htm?iid=homepage+hdr_contact Contact PresalesN/ADesktop Motherboards, Server Products,
Processors, Network and all other Intel products916-377-7000
Intel recommends that you contact your local dealer or distributor before contacting Intel07:00 to 17:00
(US Pacific Time)
Monday - Friday
HELP PLEASE !!!!!!!!!!!
We have recently built a computer with the following components
· CPU
o Intel Core i7-860 Lynnfield 2.8GHz LGA 1156 95W Quad-Core Processor BX80605I7860
· Motherboard
o GIGABYTE GA-P55-USB3 LGA 1156 Intel P55 USB 3.0 ATX Intel Motherboard
· Memory
o OCZ Reaper Edition 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model OCZ3RPR1333C9LV8GK
· <span c...
List of things to do and check.
Use the 8pin CPU connector from your modular PSU
Update the BIOS
Have all HDD's & DVD's drives on the blue SATA ports.
Set RAM voltage to 1.65V in the BIOS
Test RAM with memtest86+
http://www.memtest.org/# downiso http://www.memtest.org/# downiso
Test your HDD with Lifeguard Diagnostic.
http://support.wdc.com/product/download.asp?groupid=608&sid=30&lang=en http://support.wdc.com/product/download.asp?groupid=608&sid=30&lang=en
If none of the above fixes your problem replace the PSU
Johnny_Y_Intel
Try this way, please increase memory voltage a little, like from 1.5V to 1.55V or 1.6V and see if helps...
Your motherboard is a Gigabyte brand. For faster solution to your problem it is better that Gigabyte manufacturer's website or tech support be consulted.
