16961 Discussions
i have core i7 socket 1150 3.4ghz 8mb cache 22nm processor and i cannot find latest driver
with intel driver update utility it says no drivers were detected for your product .older driver tab is also empty.
when i try to download manually from search in your site it shows me ''intel graphic driver for windows 10 [15.40] [4th gen]''
problem is it says its a graphic driver., mine is processor.so iam not sure where to find proper one.windows 10 can only find 2009's driver for processor
thank you
it might be stupid question but i need an answer iam noob
AlHill
You did not provide your processor model number.
However, that does not matter as there are no drivers for the processor.
For more assistance, provide your processor model number, motherboard manufacturer and model, and what drivers you believe you need.
Doc
core i7 4770 socket 1150 3.4ghz 8m cache 22nm processor
asus gryphon z87 motherboard
gtx770 video card
I just upgrade to win 10 and did format to it.Win 10 get seems to found all my drivers but iam concerned about getting the latest drivers.
I downloaded video card driver manually.i checked a program called driver booster from iobit but didnt use that after reading some bad comments about it.also it said your video card driver is old after i installed latest driver.
so i dont know what drivers i need anymore after more search ,frusturated.
thanks for your assistance
AlHill
This is your processor: http://ark.intel.com/products/75122/Intel-Core-i7-4770-Processor-8M-Cache-up-to-3_90-GHz Intel® Core™ i7-4770 Processor (8M Cache, up to 3.90 GHz) Specifications
It supports Intel HD graphics 4600. This is the latest driver for your Intel Graphics: https://downloadcenter.intel.com/download/26079/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen https://downloadcenter.intel.com/download/26079/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-
You can find other drivers for HD 4600 graphics here: http://www.intel.com/content/www/us/en/support/graphics-drivers/intel-hd-graphics-4600-for-4th-generation-intel-core-processors.html Intel® HD Graphics 4600 for 4th Generation Intel® Core™ Processors
However, you have an NVidia-based graphics card. You should get the latest driver for that card from here: http://www.nvidia.com/download/driverResults.aspx/104726/en-us NVIDIA DRIVERS GeForce Game Ready Driver WHQL I do not know if your board supports using both Intel HD 4600 and your GTX 770 concurrently. If it does, I would use the GTX 770. If it does not, I would disable the Intel HD 4600 (do so in the bios), and just use the GTX 770. Just my personal preference.
As far as other drivers and bios updates, I would get them from here: http://www.asus.com/support/Download/1/45/2/2/1rZrl1Syxkizi57k/45/ ASUSTeK Computer Inc. -Support- Driver & Tools - GRYPHON Z87
Doc
P.S. Personally, I would never use ANY of those "driver update" or "driver booster" programs you find on the web.
when i try to run drivers for motherboard from
it say application not found
AlHill
What specifically are you running from the ASUS site? It sounds like a missing application from the ASUS site. If so, you must contact ASUS for support with their site.
Doc
i dont know what you mean by missing application but here is my problem:
i installed ''driver booster'' again for only to learn which drivers i need to update.then i go to device maganer and find devices which ''booster'' says.I tryed to donwload drivers automaticly from windows.Windows found some of them but not all of them.Which those windows founds even isnt the latest ones for some of them.And most of the devices which iam trying to find their drivers ,belongs to intel.
for example there is something like ;
''IDE ATA/ATAPI controller'' tab and underneeth that ''Intel(R) 8 series/C220 Chipset Family SATA AHCI controller'' when i click for properties of it it says its driver provider is intel.
thats my problem i cannot find that spesific device drivers from intel.And there is 8 of devices needing for new drivers.and another problem is some of the devices names are changed after windows updater finds newer drivers.
sorry about my bad english grammer.i would be glad if you understands what iam trying to point.
thank you
AlHill
You said that "the missing application" occurred with the ASUS link/site.
Use the links I provided.
Doc
Hello, All:
syriam, please try the suggestion above, Al_Hill is providing the right links for Intel® HD Graphics drivers, ASUS and NVidia. Try installing them manually and let me know how it goes.
Keep me posted.
Amy.
Hello, /thread/104326 syriam:
I am following up your thread; were you able to install the drivers mentioned above?
Let me know your findings.
Amy.
