i3-2100 memory
Vegan
I have an i3-2100 stuffed into an Asus P8H61-M LE/CSM, latest BIOS etc, Windows 10 x64 but that is not important
right now I have a pair of Kingston DDR3-1333 sticks on the board that seem to be stable
so I was wondering what issues i might experience with various memory configurations, i.e. is the CPU cable to cope with all JEDEC widths of chip etc?
I was looking at possibly getting a pair of 8GB sticks for the board
Hi Vaegan,
I suggest you to try with the following list, to check your System RAM compatibility. If it does not help, I would recommend you to contact your OEM and ask them for your System RAM compatibility.
In this link you will find a list of compatible memory for your desktop board
https://www.asus.com/Motherboards/P8H61M_LE/HelpDesk_QVL/ https://www.asus.com/Motherboards/P8H61M_LE/HelpDesk_QVL/
Asus Support
http://www.asus.com/support/ http://www.asus.com/support/
Hellen.
Hello, vegan:
I was checking this thread and I would like to know if your inquiry was solved.
As a friendly reminder, in order to get the compatible RAM for your system you are required to check the supported memory by your Motherboard as well as your processor.
Here I add the compatible RAM for your CPU.
http://ark.intel.com/products/53422/Intel-Core-i3-2100-Processor-3M-Cache-3_10-GHz Intel® Core™ i3-2100 Processor (3M Cache, 3.10 GHz) Specifications
I look forward to hearing from you regarding this.
If any additional questions or inquiries are present, feel free to contact us back.
Esteban C
