i3 vs i5 mobile
hello guys.
i need some info on these two.
so. i3-2330m vs i5-2430m
how much do i get from going for the i5? (price difference is 10%, or here around 80$)
i want laptop for photoshop. i'm going for gt525m discrete graphic card and 4gb ram.
will there be much difference in using i5 over i3?
Adolfo_S_Intel2
Currently Intel handles information only on some of the Original Equipment Manufacturer (OEM) processors, the Intel Core i5-2430m is only available in OEM version, for information on this particular processor you will need to contact the laptop manufacturer so they can provide you comparison information on OEM processors like this one.
Intel currently has some information on the Intel Core i3-2330M located here:
http://ark.intel.com/products/53434/Intel-Core-i3-2330M-Processor-(3M-Cache-2_20-GHz) http://ark.intel.com/products/53434/Intel-Core-i3-2330M-Processor-(3M-Cache-2_20-GHz)
You can find information on i502430M here:
http://www.cpu-world.com/CPUs/Core_i5/Intel-Core%20i5%20Mobile%20i5-2430M.html http://www.cpu-world.com/CPUs/Core_i5/Intel-Core%20i5%20Mobile%20i5-2430M.html
The i5-2430M has 3 GHz maximum Turbo Boost frequency, whcih, I beleive, is true for one core only. Maximum Turbo Boost frequency for 2 cores should be 2.8 GHz, but it's not confirmed. So, the 2430M should have up to 25% better performance when both cores are active, and up to 35% better performance for one core. Real life performance will be lower if a laptop has poor thermal solution, or if there are some bottlenecks in the system (slow GPU while you do a lot of graphics, or slow disk / not enough memory when you need to process huge amounts of data, etc).
Gennadiy
