Been having a lot of trouble over the last couple weeks with all manner of applications crashing (browsers, games, video editing, etc.). Led me to run the Processor Diagnostic Tool, and coming up with several fails around Prime Number, Math, and GPUStressW. Frankly, not sure how to interpret these results & what to do to resolve them.
Of course, got another crash just typing this up, so really hoping for some help!
--- IPDT64 - Revision: 4.1.9.41
--- IPDT64 - Start Time: 8/17/2024 12:16:30 PM
CPU1
Genuine Intel CPU Test
Module Version: 1.0.26.64b.W
Start Time: Sat Aug 17 12:16:30 2024
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Sat Aug 17 12:16:30 2024
Total Time: in seconds: 0
CPU1
CPU Brand String Test
Module Version: 1.0.28.64b.W
Start Time: Sat Aug 17 12:16:31 2024
Test Result - PASS
Expected: Intel(R) Core(TM)
Detected: 13th Gen Intel(R) Core(TM) i5-13600K
Intel(R) Core(TM) processor detected..!!..
End Time: Sat Aug 17 12:16:31 2024
CPU1
Cache Test
Module Version: 1.0.24.64b.W
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 48
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 2048
- Detected L3 Cache Size --> 24576
Cache Size Test Passed!!!
CPU1
MMXSSE Test
Module Version: 1.0.30.64b.W
Test Result - PASS
DetectUtils64 DLL Version - 1.1.9
--- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
CPU1
IMC Test
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 32.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 bytes
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Test Passed!!!
CPU1
Parallel_PrimeNum Test
Module Version: 1.0.0.13
Start Time: 8/17/2024 12:16:31 PM
Test Result - FAIL
Parallel_PrimeNum
End Time: 8/17/2024 12:16:33 PM
CPU1
Parallel_FP Test
Start Time: 8/17/2024 12:16:33 PM
Test Result - PASS
Module AVX.exe Completed - Pass
Module Math_FP.exe Completed - Pass
AVX Test
Module Version: 2.0.31.64b.W
Start Time: Sat Aug 17 12:16:33 2024
Test Result - PASS
--- CPU Features Detection ---
..AVX is supported by this CPU..
..AVX2 is supported by this CPU..
..AVX512BW is NOT supported by this CPU..
..AVX512CD is NOT supported by this CPU..
..AVX512DQ is NOT supported by this CPU..
..AVX512ER is NOT supported by this CPU..
..AVX512F is NOT supported by this CPU..
..AVX512IFMA52 is NOT supported by this CPU..
..AVX512PF is NOT supported by this CPU..
..AVX512VBMI is NOT supported by this CPU..
..AVX512VL is NOT supported by this CPU..
..AES is supported by this CPU..
..PCLMULQDQ is supported by this CPU..
..AVX is supported by this Operating System..
Most Advanced AVX Feature Detected.. AVX2
AVX2 Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
End Time: Sat Aug 17 12:17:18 2024
Total Time: in seconds: 45
Floating Point Test
AVX is supported in your OS
Max AVX supported = AVX2
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 8.32
Error: 0
--- Floating Point Test Passed!!!---
Parallel_FP
End Time: 8/17/2024 12:17:18 PM
CPU1
Parallel_Math Test
Start Time: 8/17/2024 12:17:18 PM
Test Result - FAIL
Parallel_Math
End Time: 8/17/2024 12:17:20 PM
CPU1
Parallel_GPUStressW Test
Start Time: 8/17/2024 12:17:20 PM
Test Result - FAIL
Parallel_GPUStressW
End Time: 8/17/2024 12:17:21 PM
CPU1
DGEMM Stress Test
Module Version: 1.0.17.64b.W
Start Time: Sat Aug 17 12:17:21 2024
Test Result - PASS
DGEMM AVX2 Test Result --- PASS
End Time: Sat Aug 17 12:18:22 2024
Total Time: in seconds: 61
CPU1
Frequency Check
Module Version: 1.0.7.64b.W
Start Time: Sat Aug 17 12:18:22 2024
Test Result - NO COMPARE OPTION USED
Processor Name: 13th Gen Intel(R) Core(TM) i5-13600K
Measured Processor Frequency: 3.493903
End Time: Sat Aug 17 12:18:23 2024
Total Time: in seconds: 1
System Information
Processor Information: Family 6 Model B7 Stepping 1
Number of Physical Cores: 14
Number of Logical Cores: 20
Operating System: Microsoft Windows 11 Home 64-bit
Graphics Information: AMD Radeon RX 6800 XT
--- IPDT64 - End Time: 8/17/2024 12:18:23 PM
--- IPDT64 - Result: Fail
For anyone else having a similar issue - I seem to have resolved the issue by going into my ASUS BIOS/UEFI & turning on the XMP 1 profile instead of ASUS's XMP Tuning or XMP 2.
