16903 Discussions
i5 2400 CPU frequency and CPU load test failed?
AElez
What could be the problem? I also get message:Please check your Processor Thermal Solution. Should I install new thermal paste or better cooler? Thanks in advance
BPeng6
I would use a temperature monitoring program like HWiNFO to see what your processor temperature actually is. If they are excessive, I would go ahead and inspect the contact patch between the CPU and cooler, then reapply thermal paste. A better cooler is really only necessary if you are overclocking.
BPeng6
AElez
Thanks, I will try that and see
Allan_J_Intel1
See the following URL for tips to prevent overheating: http://www.intel.com/content/www/us/en/support/processors/000005776.html Troubleshooting: When Your Computer Overheats
Allan.
AElez
It was due to thermal paste, I also updated drivers and now it pass all tests. It does not overheat like before, max. temp. is now about 56 while gaming.
Allan_J_Intel1
Excellent, I am glad your computer is running OK..
Allan.
