i5-2410M
FrederikH
Dear Community,
I still have an old Dell Latitude laptop with an Intel® Core™ i5-2410M CPU @ 2.30GHz processor and it is not compatible with Windows 11. Which processor that is Windows 11 compatible can replace the old processor with?
Thanks in advance for your help!.
Frederik
AlHill
None.  Your processor is likely soldered down, so it cannot be replaced.  Even if it is socketed, you will  not find an 8th gen or later processor that will fit the socket.   It is really time for you to consider a complete upgrade to a new machine.
However, if you insist on upgrading to w11, you "might" be successful with this:
https://community.intel.com/t5/Processors/Processors-TPM-and-Windows-11-24H2/m-p/1647361#M79106
[W10 is this generation's XP]
Kanesmith219
The Intel Core i5-2410M is quite old and is not compatible with Windows 11 due to missing features like TPM 2.0 and newer security standards. Unfortunately, you cannot upgrade just the processor in most laptops like the Dell Latitude because the CPU is usually soldered to the motherboard. To run Windows 11, you will need a newer laptop or motherboard that supports at least an 8th Gen Intel Core processor like the i5-8250U or higher. A full system upgrade is the most practical solution.
