17278 Discussions
i5-480M vs i5-2410M, Turbo Boost
Hello! What is the maximum frequency of processors i5-480M and i5-2410M when both cores are fully loaded? If I have understood correctly, these processors can overclock itself up to 2.9 GHz (due to the Turbo Boost technology) when only one core is fully load, but i'd like to know, what is the maximum frequency of those processors when both cores are fully loaded?
P.S.:
i5-480M specs: http://ark.intel.com/Product.aspx?id=52952&processor=i5-480M&spec-codes=SLC26,SLC27 http://ark.intel.com/Product.aspx?id=52952&processor=i5-480M&spec-codes=SLC26,SLC27
i5-2410M specs: http://ark.intel.com/Product.aspx?id=52224&processor=i5-2410M&spec-codes=SR04B,SR04G http://ark.intel.com/Product.aspx?id=52224&processor=i5-2410M&spec-codes=SR04B,SR04G
If all the cores are fully loaded what you get is the nominal clock speed for each core, not the turbo frequency. For example, for 2410M it' ll be 2.3GHz.
As my observations in case duel cores fully loaded it will boost up to 2.60 GHz
