16970 Discussions
i5 6500 severely underperforming
MMatt28
I recently built my first PC using the Intel i5-6500 CPU. I noticed it is http://imgur.com/a/qA3bb dramatically underperforming performance tests, and figure something must not be set up properly. What do I need to do to get the CPU to perform as expected?
Here is my build:
PCPartPicker part list: https://pcpartpicker.com/list/sHH2WX https://pcpartpicker.com/list/sHH2WX
Price breakdown by merchant: https://pcpartpicker.com/list/sHH2WX/by_merchant/ https://pcpartpicker.com/list/sHH2WX/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor (Purchased For $174.99)
Motherboard: MSI H110M Gaming Micro ATX LGA1151 Motherboard (Purchased For $49.99)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory (Purchased For $60.47)
Storage: Crucial MX300 750GB 2.5" Solid State Drive (Purchased For $99.99)
Case: Thermaltake Core V21 MicroATX Mini Tower Case (Purchased For $39.99)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply (Purchased For $39.99)
Operating System: Microsoft Windows 10 Home OEM 64-bit (Purchased For $0.00)
Other: MechanicalEagle Z-77 Multicolor Backlit 87 Keys Mechanical Gaming Keyboard with Blue Switches (Black) (Purchased For $9.00)
Other: PNY - NVIDIA GeForce GTX 1060 3GB GDDR5 PCI Express 3.0 Graphics Card - Black (Purchased For $145.00)
Total: $619.42
The CPU has passed Intel's Processor Diagnostic Tool:
--- IPDT64 - Revision: 3.0.0.25.W.MP
--- IPDT64 - Start Time: 12/14/2016 5:31:52 PM
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Wed Dec 14 17:31:52 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
End Time: Wed Dec 14 17:31:52 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 11 degrees below max
End Time: Wed Dec 14 17:31:53 2016
Total Time: seconds: 1
CPU Brand String Test
Start Time: Wed Dec 14 17:31:53 2016
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
CPU Frequency Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Processor Name: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
Expected CPU Frequency: 3.20
Detected CPU Frequency: 3.1919
Expected Base Clock: 100
Detected Base Clock: 102.965
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Wed Dec 14 17:32:08 2016
Total Time: seconds: 15
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Wed Dec 14 17:32:08 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 302.4
Error: 0
--- Floating Point Test Passed!!!---
End Time: Wed Dec 14 17:32:10 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Wed Dec 14 17:32:10 2016
Test Result - PASS
Operation Per Second: 4.65205e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Wed Dec 14 17:32:12 2016
Cache Test
Start Time: Wed Dec 14 17:32:12 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supp...
MMatt28
I've also noticed the CPU is running at relatively http://i.imgur.com/QXL1O2I.png high temperatures. Could this be the cause of the performance issues?
I've double checked that I have the proper drivers installed, and that the stock fan that came with the i5-6500 is positioned correctly.
Hello xstayhungry:
Thank you very much for providing that information.
Normally when the processor passed the Processor Diagnostic Tool that means it should be working fine because it is a very reliable tool, however as you mentioned before it seems to be getting a little overheated.
When the PC gets overheated normally it will get freeze or it will start to throttling, eventually if it gets too hot it will go off by itself, those are the symptoms of overheating, the performance tests are usually done by 3rd party tools and the results are not always that accurate, so when you say that the processor is not performing properly you mean the PC is having those issues or it is doing something else? Please provide a description of the problem.
A BIOS update will be a good thing to try, on the following link you will find the file to do that:
https://www.msi.com/Motherboard/support/H110M-GAMING.html# down-bios https://www.msi.com/Motherboard/support/H110M-GAMING.html# down-bios
Alberto
Hello xstayhungry:
I just wanted to check if you saw the information we requested before and also if the problem still remains or if it got resolved?
Alberto
Hello xstayhungry:
We hope the issue with the processor got resolved.
If you need further assistance with this case please let me know.
Alberto
