17245 Discussions
i7-13700KF Unknown error
AttilaM
Good Morning,
Can you please have a look on my case and see if there is a solution avaliable?
PC:
13th Gen Intel(R) Core(TM) i7-13700KF 3.40 GHz
Windows 11 Home
RAM 32GB 5600
RTX4070
ASUS TUF GAMING Z690
error:
- All of the games chrases (or dont start) and some other applications as well.
- PC sometimes automatically restarts
- Intel Processor Diagnostic Tool 64bit - testing fails at "Math"
- Intel(R) Extreme Tuning Utility - all 4 test stress fails
Same error code appears:
- with different operating system W10
- with different memory modules
- CPU in an other motherboard (B760)
Solution:
- using: Intel(R) Extreme Tuning Utility - When I change the "Performance Core Ratio" to 50 from the original valule of 53 the problems disppear... Everything works fine.
Do you may know an other option? With this i am significantly reduce my CPU performance.
Thank you in Advance
RandyT_Intel
Hello AttilaM,
Based on the results of the Intel Processor Diagnostic Tool (IPDT), it appears that this unit requires a replacement. However, before we proceed with the RMA process, I have a few questions that I have detailed in my email. Could you kindly review it and provide the necessary information?
Please note that I will be creating a separate case for the replacement, and this thread will no longer be monitored. We will use email as our primary means of communication to ensure a faster exchange of details.
Thank you for your prompt attention to this matter.
Randy T.
