17158 Discussions
i7 14700 wattage locked in bios
ryderien
Hello
My cpu i7 14700, gets a total of 65 watts of power
Naturally, with the ability of Intel Turbo Boost Tech, it should be used during rendering or heavy work
This electricity will be more
But it can't
I was able to increase the power consumption with xtu
But it's not permanent, and after every time I turn it off, I have to manually reset it, which is really not what I want.
I also checked the BIOS
The option related to the lock does not allow changes
I would be grateful if any of my friends know the solution to this problem and tell me.
MB: b760-F wifi
JedG_Intel
Hi ryderien,
I understand that you are only getting 65 watts of power on your processor and for me to properly investigate this issue, please share the information below.
1. Was this working fine before?
2. Did you make any recent changes to the system?
3. Have you check the BIOS to see if the base power is on "limit"?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I look forward to your response!
Jed G.
JedG_Intel
Hello ryderien,
Jed G.
JedG_Intel
Hello ryderien,
Jed G.
