16970 Discussions
i7 2600k only 654 Marks in XTU on 4.5 (max 4,75 GHz) ?
So I am on air cooling and benchmark shows 73° as highest temperature.
Hyperthreading enabled.
I've reached more than 800 score in the past with "only" 4.4 GHz (or even lower?)
CPU-Z showed max. 1.33 V for CPU...
How is XTU score calculated?
When will I receive a reply?
Are Intel Developers not actively reading this?
Hi Daniel99,
I apologize for the time, I'm investigating about this information I'll let you know the outcome.
Hellen.
Ronny_G_Intel
Hi Daniel99,
I apologize for the delay in getting back to you.
Could you please provide more details about your concern? When you say "How is XTU score calculated?" What are you referring to?
Ronny G
