HI everyone,
Basically what I want to know is why I can't run games on my notebook.
MSI gt780DX;
i7-2630 qm 2 GHz;
16 GB RAM
AMD Radeon HD 7970M
Most games run smoothly with no problems at all. But then game like GTA V which is new or Warhammer Vermintide, both auto set the graphic options to high/ultra and when I start them graphic is perfect as it should be but gameplay is laggy, sometimes when there is a lot of moving objects on the screen and sometimes when I just stand idly, so there is no pattern here.
So i downloaded the IntelTurboBoost Monitor 2.6. It's always on top but it doesn't show the usage of the processor for some reason. Maybe I'm doing something wrong (can't figure out if there is something to be done incorrectly) so what it does is on the left side there is my processor with the blue bar that should be showing the usage but its always on the bottom, on the right side there is a green leaf with energy saver - don't know if it can be disabled/changed. And no matter what game/program i run it always stays on 0 or low or just at the bottom with the blue bar not moving at all.
Also I found that my processor is capable of running 2.9 GHz (http://ark.intel.com/products/52219/Intel-Core-i7-2630QM-Processor-6M-Cache-up-to-2_90-GHz Intel® Core™ i7-2630QM Processor (6M Cache, up to 2.90 GHz) Specifications)
So my question is:
How come TurboBoost monitor doesn't show the usage of the processor, and how can I check if it uses turbo boost to go up to 2.9 GHz.
And if anyone has answers why what I described about games is happening? - maybe it's not the processor fault?
I used new and old drivers for graphic card and the results are always the same.
P.S. I know my notebook is old and maybe it's just that. But I just want to know for sure.
Thanks in advance for any help
You need a single-threaded application with heavy CPU load for test. Best is 7-Zip archiver, disable antivirus monitoring and try to pack something large, like windows installation DVD, with limit in settings to 1 thread. Normally you should reach maximum TurboBoost value. You need also a temperature monitoring app in background, cause if CPU overheats close to Tcase value, it will stop advancing frequency.
JFFulcrum is right with his post or you can stress the processor https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU- Download Intel® Extreme Tuning Utility (Intel® XTU) .
About the Graphics I am seeing your laptop model comes (depends of the country) with a dedicated graphics, so the graphics are from AMD or Nvidia (depends from the model and country) http://www.msi.com/product/notebook/GT780DXGT780DXR.html# hero-specification Notebook - The best gaming notebook provider not from the processor.
I had Nvidia 620m but it stopped working so i got AMD Radeon HD 7970M instead
maybe its not compatible with my pc .. or there is a problem between those 2 and not in the components themselves
About the Graphics you can check with AMD.
