16898 Discussions
i7700 температура по ядрам 70 градусов но кулер не нагревается. Проверенно было 3 кулера. Это брак?
ИВени
Зоны выделенные красным еле теплые, при том что у процессора уже 65-70 по ядрам
Hello doc161rus,
I used the translate tool in order to understand your inquiry; however, the translation does not seem to be accurate. I understand that you would like to know if your processor is fine even when it does not get hot on the socket, is that correct?
Amy.
ИВени
my proccessor heated up to 70 degrees Celsius but the cooling system is cold. I tried different cooling system but the result is the same.
ИВени
Thank you for the explanation.
This behavior is actually a good thing, it means that the cooler it is working; cooling when it gets hot.
For your information, your processor maximum TJUNCTION is 100°C, so your current temperature is also good. See here for more information; http://ark.intel.com/products/97128/Intel-Core-i7-7700-Processor-8M-Cache-up-to-4_20-GHz Intel® Core™ i7-7700 Processor (8M Cache, up to 4.20 GHz) Specifications
Amy.
