Hi Intel Community,
I need help and advice from anyone who has faced a similar issue. I’ve been trying to get my i9-14900K (Batch X435J730, Serial U4R85N8401678) stable for months, and I’ve exhausted every possible BIOS tweak, but it keeps crashing. I already submitted an RMA online, but I want to see if anyone has suggestions for speeding up the process or getting a replacement faster.
What I’ve tried:
Updated BIOS multiple times to the latest version.
Adjusted P-Core and E-Core frequencies: tried 5.2–5.5 GHz.
Adaptive voltage tuning: tested 1.30, 1.32, 1.34 V.
SVID Behavior switched between Typical and Best Case.
Load-Line Calibration: Level 4.
Power limits: PL1/PL2 set to 253W each, ICC Max 307A.
Disabled Enhanced TVB, TVB Voltage Optimization, Overclocking TVB, Global Temp Offset.
RAM testing: XMP I enabled, MemTest86 passed.
Tried single stick and dual stick RAM.
Reset CMOS multiple times.
Tested stability in Windows at idle, benchmarks, and games.
What happens:
The CPU crashes instantly at boot or after a few minutes, even at idle.
It freezes, shows blue screens, or crashes during game load, even with moderate settings.
Nothing I do in BIOS can stabilize it at reasonable voltages or frequencies.
Impact:
I’m a professional PC builder and gamer. The instability has affected competitions, my reputation, and caused serious stress.
I upgraded from a 12700K expecting a stable highend CPU, but I can’t even run 5.2–5.3 GHz reliably.
I’m worried about recommending 13th or 14th Gen Intel i7/i9 CPUs to my customers if this is what can happen.
Questions / Requests:
1. Has anyone successfully stabilized a 14900K with similar crashes, or is RMA the only real solution?
2. Is there a way Intel provides replacement CPUs faster than standard RMA processing for example, through authorized retailers where I can pick up a replacement directly?
3. Could the motherboard be affected by this CPU instability, or is the damage limited to the CPU itself?
I want to avoid wasting more time on tweaks that clearly don’t work. Any advice or shared experiences would be hugely appreciated.
What I’ve tried:
What happens:
Impact:
@Najam This is your third post about the same issue. One post is enough.
No more multiple posting!
[CoPilot is a virus]
Hello Najam,
Thank you for raising this concern on the Intel Community. As AlHill mentioned, I noticed that you have multiple posts regarding this issue, and you also have an active ticket for this concern.
To prevent any confusion and ensure all updates are tracked in a single place, I will proceed with closing this thread. Please continue following your active community thread or support ticket for further assistance.
John M.
Topic Options
