17163 Discussions
intel core i3 7100 driver sorunu
berat4141
ben 7.nesil driver yüklüyorum ve her saferinde hata alıyorumresim_2023-11-27_155028477.png
IsaacQ_Intel
Hello berat4141
We strive to offer the best assistance possible, and to ensure effective communication, we provide support exclusively in English. If you have any documents or screenshots to share, kindly ensure they are in English, as this will enable us to assist you more effectively.
1.     Can you provide specific details about the error message or code you encounter during the installation of the 7th generation driver?
2.     Have you tried any troubleshooting steps or alternative methods to resolve the installation error? If yes, what were the results?
3.     Are there any other software or drivers installed on your system that might be conflicting with the installation of the 7th generation driver?
4.     Did you download the driver from the official website, and are you certain that it is compatible with your operating system version?
5.     Can you describe the sequence of steps you follow during the installation process? This may help identify if there are any specific points where the error consistently occurs.
Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
Isaac Q.
berat4141
 here you ho king,I didn't understand but you did
IsaacQ_Intel
Hello berat4141
SSU raporu için teşekkür ederiz.
Desteğimiz yalnızca İngilizce olarak verilmektedir. Konuya eklenen ekran görüntülerini çeviremeyebiliriz. Size daha iyi yardımcı olabilmek için bir çeviri aracı kullanıyoruz, bu nedenle; Çeviri tamamen doğru olmayabilir.
Sorununuzu daha iyi anlayabilmem için lütfen bana aşağıdakileri sağlayın:
1. 7. nesil sürücünün kurulumu sırasında karşılaştığınız hata mesajı veya kodu hakkında belirli ayrıntılar verebilir misiniz?
2. Kurulum hatasını çözmek için herhangi bir sorun giderme adımı veya alternatif yöntem denediniz mi? Evet ise, sonuçlar nelerdi?
3. Sisteminizde yüklü olan ve 7. nesil sürücünün kurulumuyla çakışabilecek başka yazılımlar veya sürücüler var mı?
4. Sürücüyü resmi web sitesinden indirdiniz mi ve işletim sistemi sürümünüzle uyumlu olduğundan emin misiniz?
5. Kurulum işlemi sırasında izlediğiniz adımların sırasını açıklayabilir misiniz? Bu, hatanın sürekli olarak oluştuğu belirli noktalar olup olmadığını belirlemeye yardımcı olabilir.
Isaac Q.
berat4141
hello again,ı did it all,ı downloaded it from intel's driver support,it said everything was up to date, but there was no driver,then ı looked around and saw a driver for the 7th generation in intel, ı downloaded the hardware for it and then it gave an error, it was already working, as you can see in the first place, ı tried hard, but there was no way. there is no driver, ı still don't understand why,ı was going to say that there is no driver, but it is there + there is no intel graphics or anything in the device manager for my display adapters, ı only have my graphics card
IsaacQ_Intel
Hello berat4141
Thank you for your reply.
Based on the information provided, we need a little bit more information from you. Please provide us with the following information:
1.      Which specific driver were you attempting to download and install from Intel's driver support?
2.      Have you checked the version and compatibility of the downloaded Intel driver with your system's specifications?
3.      Please provide us with a screenshot of the Device Manager> Display adapters section for further analysis.
Also, as a troubleshooting step, please try the following article:
Installing a PCI Express graphics controller disables Intel graphics. Whenever we add a discrete graphics card to the system it will disable the graphics provided by the processor unless the system has a feature in the BIOS that can provide an option to choose between integrated and discrete graphics or automatically choose the graphics controller based on the requirements for processing the graphics.
To enable intel-integrated graphics when using a discrete graphics card:
  • Enable iGPU multi-monitor in the BIOS.
  • Note that different motherboards have different names for the option, so contact the motherboard manufacturer for further confirmation.
If you prefer to use the Intel integrated graphics only:
  1. Remove the external PCI express card.
  2. Uninstall the drivers for the external PCI express card.
  3. Restart your system.
If the issue still persists:
  1. Open Device Manager.
  2. Go to Actions.
  3. Select Add legacy hardware.
  4. Click Next on Add Hardware Wizard.
  5. Select Recommended Option.
  6. Click Next.
  7. Select Display Adapters.
  8. Select Intel Corporation from Manufacturers list.
  9. Select appropriate Intel Graphics Controllers based on your CPU graphics.
  10. Click Next and follow the on-screen instructions.
If the problem continues, please inform us so that we can conduct a thorough investigation. Our goal is to assist you in resolving the issue.
Isaac Q.
IsaacQ_Intel
Hello berat4141,
We hope you are doing fine.
Please answer our questions and provide us with the troubleshooting results.
Let us know if you still need assistance. Otherwise, we will close the thread.
Isaac Q.
IsaacQ_Intel
Hello berat4141,
Best regards.
Isaac Q.
berat4141
Sir, nothing you said works for this, the settings are made in the bios, there is a multi-gpu setting, you turn it on, the Intel graphics card also comes in the update, Intel said automatically, you need to update it when the card arrives, in short, nothing you said did not work for me, but thank you, you may have given a little hint, from the bios multi-monitor sentence, other than that, it's fine. So they worked
