16871 Discussions
intel core i7 6500U
Pedhenoli
Greetings,
I'm interested in acquiring a Dell monitor, model S2721DS (QHD - 2560 x 1440 native resolution). My laptop is equipped with an intel core i7 6500U (Skylake) and a Nvidia Geforce 930M. Will my laptop support the monitor resolution (2560 x 1440) at 60Hz?
Processor Specs: https://ark.intel.com/content/www/us/en/ark/products/88194/intel-core-i7-6500u-processor-4m-cache-up-to-3-10-ghz.html?q=I7-6500U
Monitor Specs: https://www.dell.com/en-us/shop/dell-27-monitor-s2721ds/apd/210-axkp/monitors-monitor-accessories
GPU Specs: Couldn't find any reliable information.
Thanks in advance.
Esteban_D_Intel
Hello Pedhenoli,
I would like to share with you the maximum supported resolutions for the graphics adapter in your processor.
As you can see in the following website the processor supports:
  • Max Resolution (HDMI):  4096x2304@24Hz
  • Max Resolution (DP): 4096x2304@60Hz
  • Max Resolution (eDP - Integrated Flat Panel): 4096x2304@60Hz
However, due to the fact that your device is a laptop there are some other factors that we need to take into consideration. For example:
1.  Actual capabilities for supported resolutions may vary from one system to another depending on system configuration. Original Equipment Manufacturers (OEM, for instance, Lenovo*, DELL*, HP*, etc.) may limit functionality and features
2.  Available ports in the laptop and port capacity.
A great way to determine the supported resolutions for the monitor is the use of Report for Intel® Graphics Drivers. or you can refer to your laptop specifications for more information.
Note: for the Graphics report, the monitor needs to be connected in your laptop the whole time.
Esteban D.
Esteban_D_Intel
 Hello Pedhenoli,
Please let me know if you need further assistance.
Esteban D.
