17259 Discussions
intel i5-3317u Notebook
recently i buy this notebook.
the problem i have is getting really hot. about 70 - 80 Celsius.
what is the problem with this CPU?
is this a normal temperature ?
Silvia_L_Intel1
Hello PabloIT, thanks for contacting us through the Intel Communities.
I would like to inform you that the temperature is normal since the maximum temperature allowed at the processor die is around the 105°C.
If you want, you could also run the Intel® Processor Diagnostic Tool. http://www.intel.com/support/processors/sb/CS-031726.htm http://www.intel.com/support/processors/sb/CS-031726.htm
Hello, sylvia.
Can you tell me , how are you ? an official ? or a normal users here ?
Thank you for your fast response, but i can believe intel made this kind of CPU.
Things going very hot under this plastic cover.
85degres , is the hottes point i can reach . never pass that point.
i will use this tool that you gave , for future information.
Silvia_L_Intel1
PabloIT, I work for Intel. The information about the processor temperature could be found at the following URL under Package specifications.
http://ark.intel.com/products/65707/Intel-Core-i5-3317U-Processor-3M-Cache-up-to-2_60-GHz?q=i5-3317 http://ark.intel.com/products/65707/Intel-Core-i5-3317U-Processor-3M-Cache-up-to-2_60-GHz?q=i5-3317
When you mentioned: "Things going very hot under this plastic cover." Which plastic cover are you talking about?
