16974 Discussions
intel performance maximizer not compatible error
LGOTT6
i my specs as follows
asus rog rampage vi extreme omega x299 motherboard with lates bios 0802.
intel i9 10920x cpu
4x8gb 3600mhz corsair ram
i am trying to use IPM to set overclock coz when i try to oc manually through bios i get errors due to low vccsa voltage and i have no idea how to use them so trying to use this, all bios setting are at default and as recomended in the user guide except i could not locate intel wdt, tried updating drivers for motherboard resources but nothing has changed and i couldnt find it in bios either, what should i do, attaching the results from intel system support utility below, thanks.
LGOTT6
Finally with BIOS update the​ tool works flawlessly, thank you everyone.
AdrianM_Intel
Hello LGOTT6,
Thank you for the update.
We are glad to know that you were able to fix this after a BIOS update.
Hopefully, this will help other peers.
Adrian M.
