16937 Discussions
intel processor diagnostic tool cpu frequency test fails, and not sure what to do
I just built a new pc with a i7-6800k on a MSI x99a Gaming Pro Carbon with 16GB and a EVGA Geforce GTX 1070. I have been getting random blue screens on Windows 10. I thought it was heat related so I added another fan. I upgraded the power supply to 700 watts. But I still get the issues, usually only when the system is stressed like playing Overwatch. So I disabled the MSI Control Center and the Intel Turbo. When I run the Intel Processor Diagnostic Tool, I get a failure on the CPU frequency. Here is the output from the tests:
--- IntelR spbc Module Test --
Version 1.0.8.64b.W
..Retrieved Processor Manufacturer
GenuineIntel
..Retrieved Processor Brand String
IntelR CoreTM i7-6800K CPU 3.40GHz
IntelR spbc Module Test -- Pass --
--- Genuine Intel Test ---
Version 1.0.12.64b.W
Expected -- GenuineIntel
Detected -- GenuineIntel
Genuine Intel CPU Module Success
--- Brand String Test ---
Version 1.0.14.64b.W
Brand String Module Success....
--- Floating Point Test ---
Version 1.0.11.64b.W
AVX is supported in your OS
Max AVX supported AVX2
FMA3 supported
MFLOPS CycleRun Error Timesec
243.1 3740 0 1
439.205 10497 0 2
Million Floating Points per Second MFLOPS -- 439.205
Error -- 0
Floating Point Test Passed
--- Prime Number Generation Test ---
Version 1.0.13.64b.W
Ops Per Sec CycleRun Error Timesec
93862 9 0 1
93418 18 0 2
Operation Per Second -- 93418
Error -- 0
Prime Number Generation Test Passed
--- Cache Test ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size -- 32
- Detected L1 Inst Cache Size -- 32
- Detected L2 Cache Size -- 256
- Detected L3 Cache Size -- 15360
Cache Module Success
--- MMXSSE Test ---
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - Intel MMX Technology Supported -- Yes
SSE - Streaming SIMD Extensions Supported -- Yes
SSE2 - Streaming SIMD Extensions 2 Supported --Yes
SSE3 - Streaming SIMD Extensions 3 Supported --Yes
SSSE3 - Supplemented SSE 3 Supported --Yes
SSE4.1 - Streaming SIMD Extensions 4.1 Supported --Yes
SSE4.2 - Streaming SIMD Extensions 4.2 Supported --Yes
--- MMX SSE capabilities check complete ---
Testing MMX
Dot Product computed using C code 506
Dot Product computed using MMX intrinsics 506
MMX Dot Product Computation Test Passed
Passed MMX Test
Testing SSE
Dot Product computed using SSE intrinsics 506
SSE Dot Product Computation Test Passed
Passed SSE Test
Testing SSE2
Complex Product computed using C code 23.00 -2.00i
Complex Product computed using SSE2 code 23.00 -2.00i
SSE2 Complex Product Computation Test Passed
Passed SSE2 Test
Testing SSE3
Complex Product using C code 23.00 -2.00i
Complex Product using SSE3 code 23.00 -2.00i
SSE3 Complex Product Computation Test Passed
Passed SSE3 Test
Testing SSSE3
SSSE3 Absolute Value Tests Passed
SSSE3 Arithmetic Tests Passed
SSSE3 Dot Product Test Passed
Passed SSSE3 Test
Testing SSE4.1
SSE4.1 Blend Tests Passed
SSE4.1 Min Max Tests Passed
SSE4.1 Insert Bit Tests Passed
SSE4.1 Extract Bit Tests Passed
SSE4.1 Bitwise Comparison Tests Passed
SSE4.1 Dot Product Test Passed
SSE4.1 Arithmetic Tests Passed
SSE4.1 Bit Conversion Tests Passed
SSE4.1 Bit Compare Test Passed
Passed SSE4.1 Test
Testing SSE4.2
SSE4.2 Bit Compare Test Passed
SSE4.2 Calculate Bit Set to 1 Test Passed
SSE4.2 CRC Test Passed
Passed SSE4.2 Test
MMXSSE Module Success
--- FMA3 Test ---
Version 1.0.10.64b.W
--- CPU Features Detection ---
FMA3 - Supported -- Yes
Testing FMA3....
FMA3 Test Result --- PASS
FMA3 Module Success
--- AVX Test ---
Version 2.0.8.64b.W
AVX - Supported -- Yes
AVX2 - Supported -- Yes
AVX512 - Supported -- No
AVX OS Support - Supported -- Yes
AES - Supported -- Yes
PCLMULQDQ - Supported -- Yes
Testing Most Advanced AVX Feature - AVX2....
AVX2 Test Result --- PASS
Testing AES
AES Test Result --- PASS
Testing PCLMULQDQ
PCLMULQDQ Test Result --- PASS
AVX Module Success
--- Integrated Memory Controller Test ---
Version 1.0.8.64b.W
StatusFMmatched 0
--- Reading Memory Size ---
Detected Memory Size is -- 16.00GB
--- Subtest - Memory Size Test Passed ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Te...
Hello melinn99,
Thank you for contacting Intel Communities.
I am sorry to hear you are having issues with the processor.
Can you please confirm the following information to better assist you?
  1. Do you have the latest BIOS version installed? (version 1.3)
    1. https://us.msi.com/Motherboard/support/X99A-GAMING-PRO-CARBON.html# support_download Support For X99A Gaming Pro Carbon
  2. What is the frequency of the RAM? (as seen in the BIOS)
I hope to hear from you soon.
Juan V.
The memory is Hyperx 16GB DDR4 - 3000 CL 15 and it shows in BIOS as running at 3001MHz.
The BIOS version is E7A20IMS.130, so it is 1.3
Hello melinn99,
Based on the information you are providing (RAM @3001 MHz), the system is running out of specifications.
Altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications.
The max supported RAM speed by the https://ark.intel.com/products/94189/Intel-Core-i7-6800K-Processor-15M-Cache-up-to-3_60-GHz Intel® Core™ i7-6800K Processor is 2400MHz. I would recommend downclocking the RAM to see if the issue persists; however, having the system running at those frequencies may have damaged the processor by now.
I hope this helps.
Juan V.
HMMM, ok. I didn't know. I set the RAM to 2400MHz, and when I run the processor tests now it passes. I'll have to play with it awhile to see if the blue screen issues still occur now. Thank you
Hi melinn99,
Thank you for letting me know.
I will be awaiting the outcomes.
Juan V.
After spending the evening stressing the system, so far it hasn't crashed once, and it definitely would have by now. Overall the system is running much cooler than it had been too. I was concerned about over clocking the processor, but I didn't think about the memory. Thanks.
Hi melinn99,
I am glad to hear the system is working now.
Please don't hesitate in contacting us back if you need further assistance.
Juan V.
