17157 Discussions
intel turbo boost monitor 2.6 win 8
intel turbo boost monitor 2.6 it worked fine in win7 64bit but not in win8 64bit
Description:
Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: signalislandui.exe
Problem Signature 02: 2.6.2.0
Problem Signature 03: 4fc67e6a
Problem Signature 04: SignalIslandUi
Problem Signature 05: 2.6.2.0
Problem Signature 06: 4fc67e6a
Problem Signature 07: 2b
Problem Signature 08: dd
Problem Signature 09: System.NullReferenceException
OS Version: 6.2.9200.2.0.0.256.48
Locale ID: 2077
Adolfo_S_Intel2
It is possible that this tool is not fully compatible with Microsoft* Windows* 8, keep in mind that this is a very new operating system that is just about to be released.
So Intel might need to release a newer version, I would suggest waiting couple of weeks to see if Intel releases an update of the tool.
GKnig2
Same problem here.
Sony F Series VPCF137HG
Intel i7-740QM
Problem signature:
OS Version: 6.3.9600.2.0.0.256.48
Locale ID: 3081
Silvia_L_Intel1
GregK, I was able to install the Intel turbo boost 2.6 on windows 64bit. Something very important is that this utility works only on Windows 8 legacy desktop.
The following link will provide you additional information http://www.intel.com/support/processors/sb/CS-031441.htm http://www.intel.com/support/processors/sb/CS-031441.htm
I took some pictures from my system in order to show you that it is actually working.
