16950 Discussions
is there a way to check hyperthreading ??
Noisyboy
i have an i5-8250U.... and it is lacking the speed that u would expect from an i5 processor especially an 8th gen on
LeonWaksman
You can also verify hyperthreading in Task Manager Performance tab. See the attached image.
Leon
LeonWaksman
  1. Right click on Windows icon in left down corner and enter Windows PowerShell (Admin)
Use the following command to enter the interactive wmic interface:
...> wmic
2. The following command will gather the number of cores and the number of logical processors:
wmic:root\cli> CPU Get NumberOfCores,NumberOfLogicalProcessors /Format:List
Result: If the number of logical processors is greater than physical processors (cores), then hyperthreading is enabled.
Example1:
C:\Users\Spock>wmic
wmic:root\cli>CPU Get NumberOfCores,NumberOfLogicalProcessors /Format:List
NumberOfCores=4
NumberOfLogicalProcessors=8
wmic:root\cli>exit
Leon
LeonWaksman
Leon
