16967 Discussions
machine check exception on core i7 5775c
MKorz1
When i try to start a Microsoft Office 2016 app like Outlook, word or Excel my pc freezes and i get a blue screen with a "machine check exception" error massage. After i googled this i found out that there are several users having the same error with broadwell-cpus. Is there a generall fix arround? I just built my new pc last week with a asus z97a Mainboard 16bg ram and a crucial ssd. I allready updated every Driver i could think of. Still i can't use Office and most likely other programs as well.
OMiro1
There is known problem with Broadwell CPU & Office 2016 (and other apps that uses virtualization). New BIOS for your motherboard was just published on ASUS site. Could you please try it and tell us if it repairs problems with Office? I hope it does...
Oskar
EstebanA_C_Intel
Hello Marcus_64:
I was able to find some troubleshooting steps provided directly by Microsoft support for this situation.
Basically the troubleshooting would be to access the Office application with the problem in safe mode and then see if the system crashes or not.
If the system works fine, then some "COM Add-in" would have to be disabled during the safe mode.
Here you can find the Microsoft support link: https://answers.microsoft.com/en-us/office/forum/office_2016_preview-outlook/outlook-2016-preview-crash-bsod-on-launch/c38aface-9895-4874-80b8-842bb5fe099d/?auth=1 Outlook 2016 preview crash (BSOD) on launch - Microsoft Community
Finally, if you encounter with any additional questions or concerns, do not hesitate to advise me.
Esteban C.
MKorz1
Thank you Esteban C
but unfortunately that doesn't help at all. Outlook doesn't start in safe mode, so there is no problem with COM Add-ins.
Marcus
OMiro1
Oskar
MKorz1
It works!!!
Thank you Oskar
and thanks to ASUS
BIOS 2801 works perfectly - so far
EstebanA_C_Intel
Hello All:
Thank you mirosz for the information provided regarding the fix for this specific case.
The recommendation would be to check the release notes for the latest BIOS of your Motherboard to check if the issue has been fixed for that release.
Do not hesitate to advise us if the issue persists.
Esteban C
