netwbw02.sys
WJonk
I purchased a brand new HP Spectre X360 with i7 processor with Windows 8.1.
In some cases I get the windows bleu screen with :
DRIVER_IRQL_NOT_LESS_OR_EQUAL netwbw02.sys.
Is the solution an update of the Wifi driver?
Isn't it strange that this happens with a brand new high end laptop?
grt, Wim
Kevin_M_Intel
Hello WimJJJ,
There are some reports from customer In the Microsoft community about this and it seems this could be caused by the router or access point:
http://answers.microsoft.com/en-us/windows/forum/windows8_1-system/driverirqlnotlessorequal-netwbw02sys/7fbb92cd-423e-4c40-ac76-d8d4fead8612 http://answers.microsoft.com/en-us/windows/forum/windows8_1-system/driverirqlnotlessorequal-netwbw02sys/7fbb92cd-423e-4c40-ac76-d8d4fead8612
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Try updating the BIOS of the computer and update the wireless driver. Testing another connection would do the trick.
Kevin M
GHong3
I also meet same issue for many times at my Spectre x360, which is not related with the WIFI route or access point.
Even if uninstall all WIDI related software/drivers and update to latest WLAN driver from HP website, the BSOD still occur...
Any solution?
The following is parts of dump file.
READ_ADDRESS: ffffe00425df8b78
CURRENT_IRQL: 2
FAULTING_IP:
Netwbw02+64f1a
fffff800`bf34ef1a 43399cac7c1b0000 cmp dword ptr [r12+r13*4+1B7Ch],ebx
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
PROCESS_NAME: System
ANALYSIS_VERSION: 6.3.9600.16384 (debuggers(dbg).130821-1623) amd64fre
DPC_STACK_BASE: FFFFD001417A2FB0
TRAP_FRAME: ffffd0014179a630 -- (.trap 0xffffd0014179a630)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000002 rbx=0000000000000000 rcx=fffff8026eef00b0
rdx=fffffffffd15b2c8 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800bf34ef1a rsp=ffffd0014179a7c0 rbp=ffffd0014179a8c0
r8=0000000000000000 r9=0000000000000000 r10=0000000000000000
r11=ffffe000243affb8 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe nc
Netwbw02+0x64f1a:
fffff800`bf34ef1a 43399cac7c1b0000 cmp dword ptr [r12+r13*4+1B7Ch],ebx ds:00000000`00001b7c=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff8026ed667e9 to fffff8026ed5aca0
STACK_TEXT:
ffffd001`4179a4e8 fffff802`6ed667e9 : 00000000`0000000a ffffe004`25df8b78 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffffd001`4179a4f0 fffff802`6ed6503a : 00000000`00000000 00000000`00000000 ffffe000`1fb8a800 ffffe000`25d4b050 : nt!KiBugCheckDispatch+0x69
ffffd001`4179a630 fffff800`bf34ef1a : 00000000`00000000 ffffd001`4179a8c0 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x23a
ffffd001`4179a7c0 00000000`00000000 : ffffd001`4179a8c0 00000000`00000000 00000000`00000000 ffffd001`4179a960 : Netwbw02+0x64f1a
STACK_COMMAND: kb
FOLLOWUP_IP:
Netwbw02+64f1a
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: Netwbw02+64f1a
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Netwbw02
IMAGE_NAME: Netwbw02.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 54857262
FAILURE_BUCKET_ID: AV_Netwbw02+64f1a
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:av_netwbw02+64f1a
FAILURE_ID_HASH: {fc89cfb0-6ad8-cff2-117d-b4ea381177a6}
Followup: MachineOwner
Kevin_M_Intel
Thank you for providing this information. This specific error is related to the wireless Driver so you should post your question here:
/community/tech/wireless https://communities.intel.com/community/tech/wireless
Another very good idea is to report this to the Computer Manufacture so they can handle and support your product.
Kevin M
