16915 Discussions
new system I7 5930k and boot issues
MRios2
I just built up a new system
I7 5930k
Water cooling ( Corsair H100i GTX)
Gigabyte 970 G1 Gamer video card
Asus x99 Pro USB 3.1 motherboard
Corsair LPX 2666Mhz 32Gb DDR4 memory
Samsung 850 EVO 1 Tb SSD drive
Samsung 950 Pro 500 GB SSD drive
Corsair RM 750w PSU
That was my first version. I managed with a lot of trouble to get Win 7 Pro 64 bit installed.
But it was never stable. All my browsers crashed, All my 2 games crashed, Any application would crash. The CPU was @ 3.7 Ghz and the memory @ 2666 Mhz. Not all updates would install, even windows 10 upgrade.
Searching the net had me testing the memory. 48 hours and 8 passes, produced no errors.
More research led me to believe it was the videocard. So I swapped out for a 960ti, still the same problems. Then I swapped to a new motherboard. And memory of 32 Gb but at 2133Mhz DDR4 to keep the CPU and memory to stock clock. Same issues. If anything now I can maybe boot into Windows 7 safe mode, keeps hanging at class_pnp.sys. The windows boot manager no longer boots to the desktop, but BSOD with page fault error. A reinstall from either CD or USB hangs in the same spot and I get the BSOD page fault error, so I can't even repair or reinstall the OS. In safe mode ( when I can get in ) I manged to download the Intel Processor Diagnostic tool will not install in safe mode. Searching MS website for pagefault error points towards RAM or L2 memory.
MSI x99S SLI
Gygabyte 970 G1 Gamer
Crucial 32Gb DDR4 2133
Corsair RM 750w PSU
This is how the system stands now. One thing I did note was a Windows PE boots to the desktop, since it's 32 bit. Memtest works since it also 32 bit. In fact pretty much all rescue utilities boot since they are all 32 bit. I made a WinPE x64 boot, and sure enough it crashed ( BSOD ) in the same spot with the same error as a Win7 64 bit ( OEM ) install disk.
My question - can the CPU be damaged to the point will it works ( somewhat ) in 32 bit environments, be it the OS or a Linux rescue based disc, where as in 64 bit environment it's crashes or locks up? I have ruled all other hardware except the CPU and PSU, and I do not think the PSU is under voltaging the CPU. Have you ever seen a issue like this?
AJana1
Valued Contributor I
Hello MikeRiosNUC,
Please allow me to guess this situation (problem) might be caused by inappropriate memory configuration under UEFI/BIOS. Please refer to http://dlcdnet.asus.com/pub/ASUS/mb/LGA2011/X99-PRO_USB31/E10131_X99-PRO_USB_3-1_for_web_only.pdf http://dlcdnet.asus.com/pub/ASUS/mb/LGA2011/X99-PRO_USB31/E10131_X99-PRO_USB_3-1_for_web_only.pdf, turn to page 3-19. Pay attention to DRAM Command Rate and so forth. I wish you good luck!
Aaron Janagewen
IUman
Hello MikeRiosNUC,
Thank you for joining the Intel communities.
Please try updating the motherboard BIOS, you can do it from the MSI website or ASUS website if you are using the ASUS motherboard.
Do you have another hard drive that you can try or maybe another SATA cable that you can use?
Also you can try removing every component in your system and then install one at time to see which one gives you the problem.
Ivan
AJana1
Just wait a minute! This system is working under the abnormal condition, especially for memory sub-system. Updating BIOS in this situation might halt the system permanently! I just suggest MikeRiosNUC to test this system with other memory modules, or contact ASUSTek before any operation towards changes of firmware.
MRios2
Janagewen -
ivanu_intel -
Both motherboards have been updated to current BIOS, current build is the MSI. Swapped out the main drive for a SATA HDD to see if it was the SSD that messing things up. Same issues. booted to Linux Live CD with 32 bit and 64 bit, 64 bit hang or has issues, 32 bit is still somewhat buggy, but somewhat useable. Tried the UEFI with Intel IPDT on it, 64 bit version, it runs right up to the point of stopping after it find the intel NIC and loads a NIC for testing, there it hangs. MSI BIOS has no setting for DRAM Command Rate, all memory sub timings settings are auto, so am not not sure you mean by abnormnal condition. I did replace both sata cables, from the MSI kit. I have tried pretty much everything. I checked the report from the breif IPDT session, it seems to pass all tests on the CPU, not sure how the L2 cache is tested, since the page_fault error as far as I have read, points to memory or L2 cache. BTW I tested the 2666Mhz memory modules with the ASUS board, and the 1333Mhz memory modules with the MSI ,and since the issue ( page_fault error ) repeats with both builds and both memory kits, that's why I am thinking it's the CPU mem controller or L2 Cache. Results below - ( speed step and turbo were turned of prior to running the test )
Intel(R) Processor Diagnostic Tool - version 3.1.64b.UEFI
Intel(R) Processor Diagnostic Tool Test Results:
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
63 degrees C below maximum
Detected Brand String:
Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
64 degrees C below maximum
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 3.50GHz
Detecting CPU Frequency ...
Detected CPU Frequency --> 3.5000
CPU Frequency Test Passed with Warning!!!
The processor frequency could be affected by power management features. In
order to ensure the processor frequency is not affected by a power management
setting, enter BIOS, load defaults, and disable any 'Over-Clocking' or power
management features that may affect processor frequency. Also, set any
software applications which control power management features to default.
--- Reading Cache Size ---
-Detected L1 Data Cache Size --> 4 x 32
-Detected L1 Inst Cache Size --> 4 x 32
-Detected L2 Cache Size --> 1024
-Detected L3 Cache Size --> 15360
Cache Size Test Passed!!!
--- CPU FEATURES DETECTION FOR ---
--- MMX/SSE/SSE2/SSE3/SSSE3/SSE4.1/SSE4.2 ---
(MMX) - Intel MMX Technology Supported --> Yes
(SSE) - Streaming SIMD Extensions Supported --> Yes
(SSE2) - Streaming SIMD Extensions 2 Supported --> Yes
(SSE3) - Streaming SIMD Extensions 3 Supported --> Yes
(SSSE3) - Supplemented SSE 3 Supported --> Yes
(SSE4.1) - Streaming SIMD Extensions 4.1 Supported --> Yes
(SSE4.2) - Streaming SIMD Extensions 4.2 Supported --> Yes
MMX Test PASS...
MMX Test Cycle Count = 100
SSE1 Test PASS...
SSE1 Test Cycle Count = 100
SSE2 Test PASS...
SSE2 Test Cycle Count = 100
SSE3 Test PASS...
SSE3 Test Cycle Count = 100
SSSE3 Test Required.
SSSE3 Test Cycle Count = 100
SSE4.1 Test PASS...
SSE4.1 Test Cycle Count = 100
SSE4.2 Test PASS...
SSE4.2 Test Cycle Count = 100
--- MMX_SSE - capabilities check complete ---
--- Running Base Clock test ---
Expected Base Clock --> 100 MHz
Detected Base Clock --> 100 MHz
Tolerance accepted --> 7
Base Clock test Pass ---
--- Running Floating Point test ---
MFLOPS CycleRun CycleVerified Error Time(sec)
14.4 1 1 0 1
403.2 29 29 0 2
403.2 57 57 0 3
417.6 86 86 0 4
403.2 114 114 0 5
403.2 142 142 0 6
403.2 170 170 0 7
417.6 199 199 0 8
403.2 227 227 0 9
403.2 255 255 0 10
403.2 283 283 0 11
403.2 311 311 0 12
Million Floating Points Per Second, MFLOPS --> 403.2
Error --> 0
Floating Point Test Pass---
Test Pass with Relative Error of Zero---
--- Running Prime Number Generation Test ---
Ops Per Sec CycleRun CycleVerified Error Time(sec)
3322895 5 5 0 1
6645790 15 15 0 2
Operation Per Second --> 6645790
Error --> 0
Prime Number Generation Test Pass---
--- IMC Test Disabled ---
--- Running IGD test ---
.Query 1..
--- Querying for Intel(R) Integrated Graphics Device (IGD) ---
..Did not detect Intel(R) Integrated Graphics Device (IGD).
..This could be that the test platform is using a discrete graphics card.
..To test IGD, verify that there is an onboard video connector,
..shutdown the test platform, remove the graphics card, and
..move video cable from graphics card to onboard video connector
..Skipping Intel(R) Integrated Graphics Device Presence Test..
AJana1
Sorry, I am not good at MSI products, so I could not help you.
IUman
Hi MikeRiosNUC,
I sent you a private message.
Ivan
AJana1
If you have some good ideas or solution, I just wish you post to the public, not only help this user but also everyone who has the similar problems/questions!
MRios2
To all -
I sent the computer to be looked at to see if the tech can figure out the problem. I 'll post updates so all can gain knowledge of what can go wrong in a new x99 build.
AJana1
Great! Expectations to your good news! Thank you!
MRios2
Just an update
the computer place said is was the motherboard, so they are going to swap it out. But I am not convinced until I get it back as they are just going to install Windows. I still have to install the browsers and my apps to see if I get the same errors as before. They told me they swapped out with another identical motherboard ( MSI x99 s SLI Krat Edition ) , but they were only to the part of the Windows partitioning the drive.
MRios2
Update -
got the computer back Friday, have spent most of Friday night and Saturday morning trying to get ANY OS installed ( Win7 preferred, but even Win 10 ). Win 10, well I managed to get to a crippled desktop, to the point where it goes into a reboot loop an sometimes ( depending on how I set the BIOS ) the infamous page fault error BSOD. As for Win7, via either USB ( via bootx64.efi added in sources folder ) or DVD, same page fault error, it will not make it to the set up screen. Mother was replaced with same unit ( MSI x99 s SLI Krate Edition ), so I am still not ruling out the issue of the CPU being the source of all my problems. Looks like it's going back, they want 100.00 to install Win7, Ill pay it if they suceed, but then I got to know what BIOS setting they did and exactly how they did if if not by DVD.
AJana1
Do you mean the problem is coming back even if you have replaced the mobo with exactly the same model? In my guess (speculations), the problem might lie on processor and/or memory modules! That is quite often, when memory modules are working in unstable conditions! The possible unstable conditions are listed below:
1. Both the memory modules and processor (memory controller) are alright, but the memory modules are working in an unstable configuration.
This is quite often especially when the SPD (or something similar) data is faked, or mis-recognised by firmware.
The solution is that setting the parameters in SETUP/BIOS/UEFI correct manually!
2. Maybe something wrong (physically) with the memory controller (processor) and/or memory modules.
Solution: replace the processor and/or memory modules.
3. Something wrong when the mobo was designed, the interrupts of some devices might halt (BSOD) the entire system.
Solution: 1. Replace the mobo with some other kind.
2. Troubleshoot which device cased the entire system unstable, and disable it, and replace it with plugin card.
3. Waiting for the solution provided by the manufacturer of the mobo
You might also ask for help from the vendors/manufacturers of your mobo and memory modules, to hear what they say! I wish you good luck!
Have you considered trying a different power supply unit? 750 watts is probably a minimum recommended spec. It's always good to have a larger one with more buffer room in the event the system draws more needed power for what ever reason. Also, the voltage output could be an issue if you have to much draw on one rail. I believe 85%+ certified PS units have multi rails probably 3-4 if not more.
Aside from checking the recommended configuration specs for memory processor frequency and such. Power output is also a consideration that needs to be looked into. A GTX 970 uses 170 watts. The 5930x uses about 130ish max load? So between all other devices you could be hitting the max power draw threshold?
I was going to suggest checking the motherboard input memory spec since you have DDR4 2600mhz dimms, but after reading that you had set the memory configurations to auto, that shouldn't be the issue at hand. The BSOD that occurs, is there any chance of you screen shooting the error message?
KTran10
First, find the right memory which were tested by the OEM motherboard. If it does not work, then most likely it is CPU. for the BSOD, what error message do you see, it can help to pin point the issue too
IUman
Thank you all for all the suggestions you have provided on this thread, at this point I would suggest to submit a warranty replacement for this processor at the following link:
https://www-ssl.intel.com/content/www/us/en/support/contact-support.html Contact Support
Ivan
MRios2
To all,
the saga continues, on my 4th motherboard, 2 back to back MSI x99s SLI Krate Editions went south on me, back to a new Asus x99 Deluxe motherboard. Hopefully this one sticks. Am waiting to hear back from the store where they are working on it. Last resort will be CPU replacement.
2nd update - they called back, they are going for CPU swap tomorrow, then the issue persists, swapping our the ram. This has been one frustrating build, but I am committed to getting it built.
IUman
I'm sorry for the inconvenience this has cause to you and I hope the replacement can solve your problem and that you can have a good experience with your system once is up in running.
I will really appreciate if you can let us know what will be the result after the replacement.
Ivan
AMohr1
Try to set the memory frequency to 2133MHz.
I have bought a Core I 7 5820K.
This processor runs stable on a Asus X99-Deluxe mainboard with the lastest Bios.
I have bought a quad Kit Kingston Hyper X Savage DDR4-2133 32GB (4x8GB).
MRios2
Ivan -
it was the CPU -
got back the system late Friday night, ran a stress test for close to 2 days. It works fine. Nice and stable. Replacement CPU is the same 5930k
IUman
Hi MikeRiosNUC,
I'm glad to hear to hear that now your system is up and running and I really appreciate you posted back the result after replacing the processor.
Thank you,
Ivan
