17493 Discussions
problem with processor diagnostic tool
mhawe
Hello, i have a problem with processor diagnostic tool ( front side bus unsuported , QPI unsuported and IGD detection test not found ect ...)
--- Testing Processor 1 ---
--- IPDT64 - rev 2.10.0.0.MP ---
--- Start Time: 10/23/2014 20:15:12---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 69 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i5-3570K 3.40GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 3.40
Detected CPU Frequency is --> 3.75369
CPU Frequency Test Passed with Warning!!!
The processor frequency could be affected by power management features. In order
to ensure the processor frequency is not affected by a power management setting,
enter BIOS, load defaults, and disable any 'Over-Clocking' or power
management features that may affect processor frequency. Also, set any
software applications which control power management features to default.
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 101
Base Clock test Pass ---
..QPI rate Test not supported..
..Skipping QPI rate Test..
--- Running Floating Point test ---
Million Floating Points per Second, MFLOPS --> 432
Floating Point Test Pass ---
--- Running Prime Number Generation Test ---
Operation Per Second--> 2.65832e+006
Prime Number Generation Test Pass ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 4 x 32
- Detected L1 Inst Cache Size --> 4 x 32
- Detected L2 Cache Size --> 1024
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
MMX SSE Testing Passed !!
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
AVX AES PCLMULQDQ Testing Passed !!
--- Reading Memory Size ---
Detected Memory Size is --> 4.00GB
--- Integrated Memory Controller Stress Test ---
--- Integrated Memory Controller Stress Test Pass!!! ---
Integrated Memory Controller Test Pass!!!
Chipset : Intel(R) Z77 Express Chipset
Chipset Stepping : C1
2 device connected to PCI Express Port 0
1 : NVIDIA GeForce GTX 770
2 : Contrôleur High Definition Audio
No device connected to PCI Express Port 1
1 device connected to PCI Express Port 5
1 : VIA USB eXtensible Host Controller
1 device connected to PCI Express Port 6
1 : Pont Intel(R) 82801 PCI - 244E
1 device connected to PCI Express Port 7
1 : Qualcomm Atheros AR8161 PCI-E Gigabit Ethernet Controller (NDIS 6.30)
1 device connected to PCI Express Port 8
1 : Marvell 91xx SATA 6G Controller
3 device connected to SATA Controller 1
1 : ST1000DM003-1CH162
2 : Crucial_CT120M500SSD3
3 : TSSTcorp CDDVDW SH-224DB
3USB devices detected
1 : Périphérique USB composite
2 : Périphérique USB composite
3 : Périphérique USB composite
1 device connected to Intel High Definition Audio Controller
1 : VIA High Definition Audio
--- Platform Controller Hub Test Completed!!! ---
..Query 2..
--- Querying for Intel(R) Integrated Graphics Device (IGD) ---
..Did not detect Intel(R) Integrated Graphics Device (IGD).
..This could be that the test platform is using a discrete graphics card.
..To test IGD, verify that there is an onboard video connector,
..shutdown the test platform, remove the graphics card, and
..move video cable from graphics card to onboard video connector
..Skipping Intel(R) Integrated Graphics Device Presence Test..
--- CPU Load ---
--- Load Level = 8
CPU Load Passed!!!
Temperature = 57 degrees C below maximum.
--- Test End Time: 10/23/...
Kevin_M_Intel
Hi Gaiden6867,
Please note that Front Side Bus and The QPI are old technologies that are not anymore on the newest processors so this is the reason why the Intel® Processor Diagnostic Tool fails on QPI and FSB test.
In regards the IGD as not found, is because your system is running a discrete card and the system is recognizing it as the main graphics controller.
Kevin M
mabbr
Hello all...i don't know why the cache in an i7 990x is just 1 x 32 and not 6 x 32 as for an i7 975x is 4 x 32.
Then the 1024 of the 975x vs 256 of the 990x....something wrong here?
Please help me....
I don't copy all the 2 test here..too long..just the strings:
975x
--- Start Time: 01/01/2015 12:41:15---
- Detected L3 Cache Size --> 8192
990x
--- Start Time: 01/01/2015 15:54:31---
- Detected L1 Data Cache Size --> 1 x 32
- Detected L1 Inst Cache Size --> 1 x 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 12288
Kevin_M_Intel
The 1x32 is the instant cache but if you see below, on the Detected L3 Cache Size is 12288 which means 12MB.
Checking this I see it is normal as the test has shown.
Kevin M
