processer info
Can you tell me what processor I have so I can purchase a mother board to use it. The only numbers at bottom are A1091,or N3549028 it came out of a dell computer
Try this utility to see if it identifies the CPU.
Note: Your cpu may be a Tray/OEM version, it may not recognise it.
http://www.intel.com/support/processors/tools/piu/sb/CS-014921.htm
Otherwise, read the markings on the CPU.
http://www.intel.com/support/processors/sb/CS-030330.htm
Check the SL number on:
http://ark.intel.com/
http://processorfinder.intel.com/default.aspx
All the best,
Kind Regards,
Aryan.
hi,
Can you see an SL number on the silver bit where the thermal paste goes?or any other number?
