17511 Discussions
sde errors on linux
tictoctac
I'm running an executable that uses avx512 with sde in a cpu without these instructions under linux with the following command:
/home/user/sde-external-9.7.0-2022-05-09-lin/sde -icl -- ./executable
I get the following errors:
SDE ERROR: valid
 at (no-file):329 Function (no-func)
A: /tmp_proj/sde_admin/emx/external/pin/Source/pin/vm_u/vm_signal_impl_unix.cpp: NotifyExit: 1247: assertion failed: _initialized
## STACK TRACE
??? at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/pinbin+0x0003f4fc6
LEVEL_VM::VM::Shutdown+0x00000008f at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/pinbin+0x0002ddd8f
LEVEL_VM::VM_SHUTDOWN_MANAGER::CompleteShutdown+0x00000007c at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/pinbin+0x0002de5fc
LEVEL_VM::VM_SHUTDOWN_MANAGER::DoShutdown+0x000000083 at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/pinbin+0x0002e1593
LEVEL_VM::VM_Shutdown+0x0000000a4 at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/pinbin+0x0002e22c4
??? at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/pinbin+0x00024e51a
??? at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/sde-mix-mt.so+0x0004c390a
??? at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/sde-mix-mt.so+0x0000f60e1
??? at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/sde-mix-mt.so+0x0001a7a3b
??? at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/sde-mix-mt.so+0x0001a73d6
??? at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/sde-mix-mt.so+0x0000657e3
??? at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/sde-mix-mt.so+0x000065e38
main+0x000000096 at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/sde-mix-mt.so+0x000023e76
LEVEL_INJECTOR::UNIX_INJECTEE::StartTool+0x0000001a0 at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/pinbin+0x00045e870
LEVEL_INJECTOR::UNIX_INJECTEE::RunMainThreadOnPinStackAttach+0x000000324 at /home/user/sde-external-9.7.0-2022-05-09-lin/intel64/pinbin+0x0004641d4
Detach Service Count: 1
Pin: pin-3.23-98579-b15ab7903
Copyright 2002-2022 Intel Corporation.
PriyanshuK_Intel
Thank you for posting on Intel Communities.
Could you please provide us with Sample reproducer and steps to reproduce the issue, so that we can investigate more on your issue from our end?
Also, please provide the compiler version being used.
Thanks & Regards
Priyanshu.
tictoctac
I cannot give the source code or the executable because it's a commercial product but I have found that sde 9.7 gives a segmentation fault also with an open source program: https://github.com/official-stockfish/Stockfish I have attached the executable generated.
I haven't used an intel compiler (I have used gcc 11.2) but I have problems with intel sde 9.7.
I have 2 different pc, one with haswell cpu and one with zen3 cpu. With haswell one sde works while with zen3 cpu the sde give segmentation fault or the error message that I have posted so I don't know if it's easy to reproduce.
Jocelyn_Intel
Hello, @tictoctac
Thank you for posting on the Intel® communities.
I am sorry to hear what is happening with your processors, I will gladly assist you here.
Can you please confirm the models of the processors you are having these issues?
Jocelyn M.
tictoctac
I have the reported errors with a ryzen 5950x.
With an Intel Core i7-4702MQ the same executables runs fine without problems.
Jocelyn_Intel
Hello, @tictoctac
Thank you for the information provided.
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it. You may also find the Discontinued Products website, helping to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Marketing Status > "Discontinued":  Intel® Core™ i7-4702MQ Processor
Jocelyn M.
