17006 Discussions
terminal message is missed when using assembler instructions
Chloé_Russell
Hi, I'm using UART connected with nios processor and an RS232 connection, when generating a software (using Eclipse) that contains a simple messages to print through the terminal, I got correct messages in my terminal screen when creating a software (using Eclipse) and coding in my C test file with assembler instructions, I got no messages in my terminal screen.
Alberto_R_Intel
Chloé Russell, Thank you for posting in the Intel® Communities Support.
In order for us to be able to provide the most accurate assistance on this matter we just wanted to confirm a few details about your system:
What is the model of the Intel® Processor?
What is the model of the motherboard?
If this is a laptop, what is the model of it?
What is the program/application that you are using?
Are you a developer?
Are you working on a project?
If that is the case what is the project about?
Albert R.
Alberto_R_Intel
Hello Chloé Russell, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Chloé Russell, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Albert R.
