16909 Discussions
wifi keeps disconnecting
Rina25
My wi-fi keeps disconnecting and whenever I try to connect, it does'nt show any wi-fi devices, even if i try to connect once the devices are shown after long time, i am mot able to operate the wi-fi tools
AlHill
Which wifi would that be?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[CoPilot is a virus]
JedG_Intel
Hello Rina25
For me to assist you properly, please share the information below.
1. Were you able to have wireless connection in a normal/expected performance before?
2. Do you remember if this issue happened after a new OS update or Wireless driver update?
3. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
4. Is this a laptop or desktop system?
5. Is this issue happening at home, office environment or both?
6. Have you checked if this issue happens on different networks?
Additionally, to have a better understanding of your system configuration and components please generate a complete copy of the System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
JedG_Intel
Hello Rina25,
Jed G.
JedG_Intel
Hello Rina25,
Jed G.
