When I try to load the program to DE2 board I get the following error:- There are no Nios II CPUs with debug modules available which match the values
specified. Please check that your PLD is correctly configured, downloading a new SOF file if necessary. I am new to FPGA. Please help meLink Copied
Did you configure the FPGA first? Ensure that both your software and the .sof FPGA image that you load are based on the same design.
yes sir i have done everything you mention and my software and .sof image are based on the same design.
