12609 Discussions
Copying projects to another PC. BSP has absolute paths
I'm trying to get a handle on how to clone my project and make it build on another PC.
But I see that my NIOS BSP uses absolute paths to access the sopc info file. Simply changing the filename in the make file wouldn't work
How do I copy a complete project along with its NIOS projects and make sure it works in another system?
Zubair
p.s. using Quartus 12 + NIOS SBT 12..
You can fix the absolute path to the .sopcinfo file by manually editing the XML file (settings.bsp). You are looking for the "<SopcDesignFile>" element, about 10 lines down from the top. Just change it to be a relative path.
The settings.bsp is the only file you actually need to copy as far as BSP files; then on each fresh PC you need to "generate" the BSP again.
Changing makefile and settings.bsp both worked.
Thanks!
Zubair
--- Quote Start ---
Thanks!
Zubair
--- Quote End ---
There is another good way to solve this problem.
First regenerate bsp.
Then in application project Index -> rebuild.
Then build project.
And then run this on hardware.
Re-indexing detects the relative current paths of the files related to the project.
Similar is the case when you regenerate your new/modified Qsys system. Same procedure.
