I'm using DE1-SOC and I have a system which streaming data from a fifo in FPGA to SDRAM by msgDMA.
I have controlled msgDMA to write the descriptor and read data from SDRAM successfully but I don't know how to register and handle the interrupt of event completing a transfer in linux application. In my qsys design, the csr_iq of msgDMA is connected with f2h_irq0 of HPS, is it correct? Is there a way to interrupt the program without writing a kernel module? I have no knowledge about writing a kernel driver. Currently, I'm trying a stupid way as below:
write_descriptor_to_base_address();
csr_ret = read_csr_status();
while(1) {
if ( (csr_ret >> 8) & 0x1) == 1) { // read the bit 9th where IRQ_ID was set
handle_event_transfer_complete();
break;
Could anyone here give me some advice to solve the problem? Thank you,
