12608 Discussions
Dear Team, Greetings!!! Can you please provide IPC class-6 document for part no EP4CGX150DF31I7N. I checked the Material deceleration link and did not find exact part no.
SMude
Abe
Valued Contributor II
You can choose the following part number in the Materials Declaration link : EP4CGX150DF31I7NAC
https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/environmental/material-decl.html
ChiaLing_T_Intel
Intel has adopted the IPC-1752 reporting format for material declaration data exchange between Intel FPGA and the downstream supply-chain participants. Generally, customers should download the IPC-1752 version 1 from the Intel web. You could download the material declaration by entering the valid Ordering Part Number and select your desired Output Type at the following link:
Thank you
Chia Ling
SMude
Hi Chia, Thanks for your quick response. Can you please confirm if the part no EP4CGX150DF31I7NAC is corrected part no for EP4CGX150DF31I7N. Since AC suffix is not available for the same. Best Regards, [ihs.com]<https://ihsmarkit.com/> Santosh Mudengudi Sourcing Engineer | Des&Sup Chain-Parts 15 Inverness Way East | Englewood, Colorado | 80112 santosh.mudengudi@ihsmarkit.com<mailto:santosh.mudengudi@ihsmarkit.com> [Facebook]<http://facebook.com/Explore.IHS>[Twitter]<https://twitter.com/IHS>[LinkedIn]<http://linkedin.com/company/ihs>[YouTube]<http://youtube.com/ihschannel>[IHS Blogs]<http://blog.ihs.com/>[Google+]<https://plus.google.com/+IhsExplore> This email message, including accompanying communications and attachments, is strictly confidential, for the sole use of the intended recipient(s) and may contain privileged information. Any unauthorized use, review, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message. Thank you. ?Please consider the environment before printing this e-mail.
ChiaLing_T_Intel
EP4CGX150DF31I7NAC  is valid part number. You can get the IPC report by entering this OPN. The device part number - EP4CGX150DF31I7NAC ended with the additional suffix 'AC' is referring to customer specific ordering suffix, the material that builds directly for some specific customer request. These are added to the device part number when a device has under gone additional qualification upon request. For general part ordering, you may look for EP4CGX150DF31I7N.
Thank you
Chia Ling
ChiaLing_T_Intel
How are you? We sincerely hope that you have resolved your issue since there is one week without any response. For any further questions, please post a new thread.
Thank you
