12610 Discussions
Display Mif / Hex file in dual port ram on Nios II stdout
I'm trying to fill a dual port ram (framebuffer) with a Mif File and then print it out with NIOS II and its C-Code programming.
The Mif File (converted to Hex) and loaded into the dual port ram looks like this:
-- quartus prime generated memory initialization file (.mif)
width=8;
depth=12;
address_radix=hex;
data_radix=hex;
content begin
0 : ab;
1 : cd;
2 : ef;
3 : 12;
4 : 34;
5 : 56;
6 : 78;
7 : 9a;
8 : bc;
9 : de;
a : f1;
b : 23;
end;
The c-code for the NIOS II looks like this (and does not work):
# include <stdio.h># include <stddef.h># include <stdint.h># include "system.h"
int main(void)
int MEMORY_FB;
MEMORY_FB = 0x5000;
volatile char *mem_fb = (volatile char*) MEMORY_FB;
int i;
for (i=0;i<13;i++){
printf("%x\n", mem_fb);
return 0;
[/I]It prints out:
ffffffab
ffffffcd
ff
How can I fix this to get "ABCDEF123456789ABCDEF123" as an output?
This is only a test for image data a camera will collect later on.
if the RAM is connected as 8Bit addressable memory:
printf("%x", 0xff & mem_fb[i]);
if the RAM is connected on a 32Bit bus teh upper bits may filled up with 0:
printf("%x", 0xff & mem_fb[4*i]);
printf("%x", 0xff & mem_fb[i]); - worked!
Thanks!
