EPCS access fail
Hi there
I'm having trouble accessing the EPCS from withing NIOS. When running the following code:
void OpenEpcsFlash()
fd_f = alt_flash_open_dev(EPCS_FLASH_CONTROLLER_NAME);
alt_printf("EPCS pointer: %x\r\n",fd_f);
fd_f always returns a NULL pointer.
I've enabled small_device_drivers and the small_c_library, but I've included the ALT_USE_EPCS_FLASH# define. If I run the exact same code on the DE0_Nano_SOPC demo project, included in the Altera DE0 Nano board, the software works. Is it possibly a setup problem in my Qsys system?
I'm using Quartus 13.1.0.
Thanks in advance
Jean
I found the problem. The# define ALT_USE_EPCS_FLASH, is removed each time the BSP is regenerated. Thus it needs to be added after BSP generation.
Hope this helps someone in the future
Kind regards
Jean
There are others cases where some user installed the EDS and tool chain in different folder location where causing the inclusion path is not updated correctly. :)
