Hi guys,
I'm running a DE2-115 with the TSE_MAC running on uCOS which i have based on the SSS Example (simple Socket Server). My DHCP has stopped getting an address and times out. After much wat=sted debugging time I have found it occirs when i enable the Gigabit ethernet in the hardware:
assign set_1000_to_the_tse_mac = 1'b0;
I swear at one point i had sucessfully had gigabit with out this problem, but i've restored through my back ups and it happens when i enable this bit in my verilog. Any ideas?
Read the docu! This bit can be set to 0 for gigabit networks. If You set this to 1, then You force the core to work on 1Gbps speed and it doesn't work on 100Mbps network.
Thanks i got tunnel vision and a bad day. I also was using the wrong router, wasn't gigabit.
Thanks for snapping me out of it.
