Execution problems
I bought the Nios 2 Evaluation Kit and I successfully ran 'count_binary' example.
After that I've made modifications in Quartus and then I've updated the FPGA with the new .sof file.
Now I'm no more able to execute count_binary. It seems that PC increments correctly through the starting line of the assembly code but sometimes the instructions are not executed correctly.
Any clues?
Thank you.
Marco
Hi Marco,
> Any clues?
What 'modifications' did you make?
--Scott
I've added a number of counters, gates, f/f, 74597, and so on.
In the sopc builder, I added various gpio, and a user interface logic to a dual port ram.
I even tried to slow down the cpu clock with no success.
Are you able to build and execute the example design (without modifications)?
yes I can!
I've just solved the problem.
I can run the modified version by slowing the clock once again. Now I'm involved in locating the problem.
Cheers,
Marco
