Expect library on uClinux
Hi everyone,
I am copiling uClinux on CycloneIV.
I need do run a script to connect to a router by ssh. For that, I have to use the library expect.
So, in the make menuconfig, I selected Expect option (Applications -> Miscellaneous Applications).
It selects TCL automatically, but despite of that, I have a mistake during the compilation :
cp openssl.pc /home/marius/nios2-linux/uClinux-dist/staging/usr/lib/pkgconfig
chmod 644 /home/marius/nios2-linux/uClinux-dist/staging/usr/lib/pkgconfig/openssl.pc
make[4]: leaving directory « /home/marius/nios2-linux/uClinux-dist/lib/libssl/openssl-0.9.8k »
make[3]: leaving directory « /home/marius/nios2-linux/uClinux-dist/lib/libssl »
make[2]: leaving directory « /home/marius/nios2-linux/uClinux-dist/lib »
make[1]: *** [all] Erreur 2
make[1]: leaving directory « /home/marius/nios2-linux/uClinux-dist/lib »
make: *** [subdirs] Erreur 1
So, I suppose that TCL needs another module, but I don't know which one.
Does somebody have the solution ?
Thanks !
Marius.
What about libssl ? you have to select it in library in "uClinux application" configuration during the "make menuconfig".
LibSSL was selected already.
So, I suppose that TCL needs something else...
I found an explanation : TCL library calls fork().
fork() needs an MMU, and I don't have in my nios.
Does somebody has another idea to do an automatic ssh connection without MMU ?
