12609 Discussions
Ext flash connection in top level block diagram
For Altera Cyclone III (3c120) dev kit, I have the following connection for ext_flash in my verilog top level:-
output [ 24: 0] top_fsa;
wire [ 24: 0] top_fsa;
wire [ 25: 0] top_fsa_alignment;
assign top_fsa = top_fsa_alignment[25 : 1];
.flash_tristate_bridge_address (top_fsa_alignment),
Can anyone please tell me how can I do this kind of connection in my block diagram?
My ext_flash in SOPC Builder setting is
Address Width - 25
Data Width - 16
Any help would be appreciated.
Carid
Draw a bus wire from the sopc component port and leave it unconnected.
Double click it and rename it as: " top_fsa[24..0],dummy "
Add another bus wire with both sides unconnected and name it top_fsa[24..0], then connect on side to an output pad symbol
Hi Cris72, thanks. But I wish to clarify your answer.
Did you mean draw 2 wires using 'Diagonal Bus Tool' and both also named as top_fsa[24..0]? Sorry it doesn't seem very clear to me.
The orthogonal bus tool is what I meant.
I attached a picture for your convenience.
I hope I correctly understood what you want.
Hi Cris, thanks for your screenshot. But I think it should look like this. I tried and it succeeds.
