12610 Discussions
FPGA-SoC on Arrow SoCKit (Fitter error)
Hello Friends,
I am trying to learn Embedded System's on on Arrow SoC Board. http://rocketboards.org/foswiki/view/documentation/arrowsockitevaluationboard
1. I following the youtube Artical for my SoC Board. i have modified things according to my board like, Device, 8 Switch and 8 LED's etc.
www.youtube.com/watch?v=2wuket4-q7q (http://www.youtube.com/watch?v=2wuket4-q7q
2. in this youtube video project--> its just a Blinking the LED through External switch. i have add only one hps and 8 led and 8 switch .
3. in my modified SoC Kit Project--> Analysis and synthesis is OK no issue. but during Fitter (Place and Route) it had lot's of error related to HPS connection. even though i have run tcl script.
I got following errors (attached) during fitter process.
Attached: (1) Project,
(2) Error Screen short,
(3) Qsys project screen short
How do i overcome this fitter problem....?
kaushalA
You should use [1] with the GHRD as Reference Design for your first try...
Kind regards
[1] http://rocketboards.org/foswiki/view/documentation/arrowsockitevaluationboard
--- Quote Start ---
Kind regards
--- Quote End ---
Thnx Taz,
I would definitely do so, but currently in this work only last step is left .... so looking for solution. so if you have any suggestion please let me know .
kaushal
You should download the GHRD and check the IO-Standards of the related PINs and also have a look to the *.tcl File for correct exclusion of fitter effort for that PINs, because they are fixed...
hello There
OK i have download the ghrd design from rocketboard.org -->compile and follow the instruction-->port to board--> its working, i mean LED Glowing in a pattern etc.
(1) Then as u mentioned in your post "check the IO-Standards of the related PINs", i assign the same IO std. to my design (HPSFPGA) as in sockit_ghrd design only to LED pins.
it add the new error's related to new assignment saying that "Pin LEDR0 is incompatible with I/O bank 3A. it uses I/O standard 2.5 V, which has.....etc". similear to previous error's
(2) How do i check .tcl script please put more light on it?.
attached is the print-screen of both design's pin planner along with error being generated.
kaushal
check the IO-Standard, it seems to be 2.5V in your Design, but has to be 3.3V LVTTL to work.
Please check that for all the Banks within your Design, but what is the obstacle, that you do not put the small amount of changes within the GHRD and compile that?
Later on you may evaluate what are the differences.
Kind regards
Hello Taz,
Thanking you for your response and time.
Yes ! i have tried what you mentioned in your post, but every time i assign the I/O to Desired Pin like "HPS_ENET_GTX_CLK" to H19 from bank 7B , it says not assignable as this bank is not visible in drop down menu in pin assignment windows. whereas i have to assign this HPS_ENET_GTX_CLK to H19 only as per data sheet. and same thing happen for rest of the pins describe in error's.
i have attached the Print-Screen for same what i have tried .
Kaushal
Hi Kaushal,
the dedicated HPS-PINs are not asignable due to a hardwired connection, try to not assign them (like in the GHRD).
Hello Taz,
OK after giving them 3.3 LVTTL I/O level all errors related to these pins has gone,
And as you mentioned in your post these are dedicated pin's so need not to be assign (What i understand).
Lastly after Fitter in assembler it says Can't save or open
D://Q13.1 User/SoCKit/db/ip/hps_fpga/submodule/sequencer/alt_types.pre.h
Thanx
Regrads
kaushal
Try to delete all db-Files or try to add the QSYS-System *.qip-File to your project-files (possible solution in [1]).
[1] http://www.alteraforum.com/forum/showthread.php?t=43484
Hello Taz,
follow both the options but problem still remain same.
1.> Remove db-Files (Then Regenerate the qsys and recompile the project)
2.> add hps_fpga.qip to project file (lead to some more errors)
kaushal
Attached Print-Screen of library path Project->Setting->Library
