Flash Programmer Error
I'm currently using the Flash Programmer included in the Nios II SBD Tools for Eclipse. When I try to generate and program flash files to my DE2-115 board from a .elf file (the code already works in 'Run' mode), I get error code 4: program failed at offset 0.
I've seen a couple of other threads saying to set a flash offset of 0x20000, but this doesn't work when you're generating from .elf files.
Any thoughts on this problem?
-N
What Quartus version are you using?
There's a link here to program from EPCS/EPCQ device using the Quartus programmer-
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd11192013_118.html
Any more error code displayed? could you place the complete error text?
I used the EPCS programmer, we're all good!
-N
