Hi everybody,
I am currently playing around with the Cyclone V SoC Development board. I have a QSys system running resembling the Golden system reference design apart from the fact that the h2f_axi_clock is controlled by a PLL residing on FPGA side. The h2f_axi_clock is 50 MHz in my case. I have an IP test (with many registers) up and running according to the GSRD and connected directly to H2F_axi_master. I used the Linux example to run a Linux (3.7) application on the HPS. From within the application I can write to and read from my IP test in the FPGA, the memory address range is mmaped to the linux user space for this purpose. Now the question: The time taken to lauch 2 read (or write ) access from an application to my IP registers was mush more than expected (we should have a bandwith of 3.5 GHZ/s I think) : According to signal tap (by tracking the chipselect signal): 1 read access takes only 40ns , (1 write, 20ns) whereas between 2 read access there is a 320 ns (same as for write access) . And my application is simple: mmap IP address writes 32-bit values to 10 registers and read back results at the end (by storing them in an array of uint32_t : uint32_t IP_reg[10]). read instruction: IP_regs[0]= *((unsigned long *) (map_base + (target & MAP_MASK)+24 ));// (10 accesses such as this one) write instruction: *((unsigned long *) (map_base + (target & MAP_MASK) +24 )) = 1;// (10 accesses such as this one) How can I accelerate several read write accesses to FPGA IPs from the HPS ? Thanks in advance, ---------------------------- My IP interface: mm_avalon Processor : 925 MHz, ARM cortex A9 dual core Board: Altera cyclone V SX SoCLink Copied
Hi Sam16,
I appreciate that this is a late reply, but thought a reply might be better than nothing. I found I would get better access using commands like memcpy rather than individual reads, but I haven't done as careful timing as you. Other options would include setting a pointer, eg ip_regs_base = *((unsigned long *)(map_base + ....); and then you can do: IP_regs[0] = ip_regs_base[0]; and ip_regs_base[0] = 1; to simplify what the compiler might generate. But memcpy is tailored to moving memory quickly and efficiently, so it will use minimal instructions to do the job. Cheers, SimonFor more complete information about compiler optimizations, see our Optimization Notice.
