NIOS II IDE question
Quick and easy question. How do I switch between files in the NIOSII IDE. Rather than find the filename in the tabs, is there an accelerator key sequence I can press. Something like the CTRL-TAB in MS Visual Studio?
thanx
Try CTRL-F6 to access next editor while CTRL-SHIFT-F6 accesses previous editor. You can have a look at the key settings in the IDE from Window->Preferences->Workbench->Keys and even change them if you want to.
