In the woking ethernet example, i have added Altera QUAD SPI controller IP (N25Q512A83GSF40F), after adding this IP NIOS console window is not printing. Is there any eclipse settings specific to QSPI IP?
Mahalakshmi
Hello Mahalakshmi,
Can you please make sure that the Makefile is been created correctly and up to date?
you can do the following to make sure the Makefileis up to date:
1- Open the BSP project folder
2- Right click the Makefile>> Delete
3- Open the NIOS II Command Shill
4- Write the following command:
cd <...../project_bsp>
nios2-bsp-generate-files --settings=settings.bsp --bsp-dir=<C:/…./<project_bsp/>
5- Build your project again.
Let me know if it works.
Isaac.
Hello Mahalakshmi,
Did the solution work?
Isaac.
Hi Issac,
Thanks for your reply.
The solution did not work, still facing the same problem.
Mahalakshmi
ok, can you share your design with us? And I could do some debugging.
You are connecting all the clock and reset lines on your NIOS design?
Best regards.
