12609 Discussions
Problem while doing SoCkit_SW_13.0 lab
I've downloaded the 'SoCKIT_Materials.zip' and do the involved labs: SoC_HW_Lab_13.0 and SoC_SW_Lab_13.0. I had problems when debugging the preloader in the SW lab:
when start debugging(click the debug button in DS-5), it first goto the reset instruction of the start.S file:
reset:
bl save_boot_params
, then jump to the save_boot_params function of the lowlevel_init.S file:
/* Save the parameter pass in by previous boot loader */
.global save_boot_params
save_boot_params:
# ifdef CONFIG_SPL_BUILD# if (CONFIG_PRELOADER_DEBUG_MEMORY_WRITE == 1)
* write the debug memory header and value of R0 - R3 (which passed
* by BootROM) into debug memory region (which is on ocram)
ldr r5, =CONFIG_PRELOADER_DEBUG_MEMORY_ADDR
ldr r4, =PRELOADER_DEBUG_MEMMORY_HEADER
stmia r5!, {r4}
stmia r5, {r0 -r3}
/* get the reset manager status register passed by BootROM */
add r5, r0,#0x34
ldr r4, =rst_mgr_status
ldr r5, [r5]
str r5, [r4]# endif /* CONFIG_PRELOADER_DEBUG_MEMORY_WRITE */
My first debug always halted at the 'ldr r5, [r5]' instruction. Then click the reset button(back to entry point) to do re-debug, and it can work correctly.
Any one knows why?
BTW, my quartus is version 13.1, and DS-5 is 5.15.0.
The problem has been solved. I found a new lab material for quartus 13.1:
http://www.rocketboards.org/pub/documentation/arrowsockitevaluationboard/sockit_materials_13.1.zip
