Profiling tools for uClinux
I realized that gprof does not work with uClinux, unfortunately.
Nevertheless, oprofile is an another solution and I tryed to install it.
But, I have problems with system's generation:
checking for dlopen in -ldl... yes checking for main in -lintl... no checking for bfd_openr in -lbfd... no configure: error: bfd library not found make: *** Error 1 make: Leaving directory `/home/carlos/uclinux/uClinux-dist/user/oprofile' make: *** Error 2 make: Leaving directory `/home/carlos/uclinux/uClinux-dist/user' make: *** Error 2 make: Leaving directory `/home/carlos/uclinux/uClinux-dist/user' make: *** Error 1
I follow tutorial http://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:oprofile
The bfd library issue is a problem very known with oprofile and I don't found any solution.
Please can you help me?
Regards!
